Dupont Clear over metallic base - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-31-2005, 05:48 PM
Had a vet painted with metallic base w/4 coats of clearcoat. The painter decided it needed to be detailed w/flames...[gold leaf paint] same as used on fire truck lettering..The painter is a friend.....He says it has to be repainted in total to fix it...Another painter says use Easy Off oven cleaner to remove the paint. This method took some off but not all of it...Didn't harm the clearcoat either...Yet....Any of you out there have any sugestions for this screw up. This was a $5000.00 paint job
Old 03-31-2005, 06:47 PM
p8nter's Avatar
Did he flame it and mess it up and now you need to take the flames off?? .
Old 03-31-2005, 07:30 PM
pro70z28's Avatar
Last journal entry: "Z" construction
I take old fire truck lettering (gold leaf / black outline in enamel usually) off with a combination of easy-off and rubbing compound. BUT, YOU HAVE TO BE VERY CAREFUL. If you take your time and are VERY careful it will come off. It may leave a little ''ghost" of the flame job though. When you rub the lettering you will be rubbing the lettering and the clear coat @ he same time. This may remove a slight amount of the clear around the flame design as you rub leaving a slightly raised flame pattern on the paint in the clear. If your fortunate enough to have enough clear you may be able to block that ghost pattern out, then bluff it. Just take each step slow and be careful to NOT break through the clear.
Old 04-01-2005, 10:15 AM
Have Gun, Will Paint
With 4 coats of clear you may be safe to cut (wetsand) the flames off and buff, but then again you don't know how much of that clear got cut off when it was first buffed.....If you can get a hold on your painter, I would ask him for advice on how to fix it. He should know if there is enough clear left to recut and buff, or give you another idea for a the fix
good luck
Old 04-01-2005, 08:05 PM
Thanks guys..I found some paint remover that supposed to take off road marking paint that won't harm finishes...As far as the painter goes...the added touchs were done for his benefit, not mine..He thought I would like it..We have been friends for some time....I would have to decide what a friendship is worth..He was going to airbrush a hooker leaning against a lamp post on the hood....I warned him not to do that...didn't think it fit my conservative way of thinking
Old 04-01-2005, 08:16 PM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
Tell you right now.
IF I even thought of doing a graphic of ANY sort on a vehicle,It would be DISCUSSED WITH THE OWNER FIRST...
I'll do a few "minor" things to upgrade something but something of ANY size is to be known upfront.
Not everyone has the same taste and the person driving it WILL decide. Weather or not I like it.
I believe you'll be safe with a color sand of the clear with some 1000 wet first to get an idea of the depth the gold went into it. That will give you a safe feel of the clear and just be on the look out for colored water.Which I don't think you'll see. Think positive. And go light.
That road paint is strong stuff so I'd be carefull with whatever you got to remove it with.
single stage vs. base clear? CAMARO Body - Exterior 38 01-30-2009 11:03 AM
Clear, No Clear, or Clear + Base? tallpaul Body - Exterior 16 01-21-2006 05:30 PM
Wetsanding Clear and Metal Flake on Edge Phillip27 Body - Exterior 11 01-20-2006 02:52 PM
Base And Clear PAS55 Body - Exterior 14 09-30-2005 08:45 AM
pinstriping base coat / clear coat apehanger mike Body - Exterior 1 01-30-2005 12:28 PM
