Dupont Nasson Chassis Black - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-30-2008, 01:13 PM
Last journal entry: 1996 Impala SS Frame Off
Does Dupont Nasson 422-05 Chassis Black require a primer over a freshly sandblasted frame?
Thanks in advance
Ray
Old 03-30-2008, 01:44 PM
Yes it does.
Data sheet says substrates are OEM finishes or primed metal.
Larry
Old 03-30-2008, 02:04 PM
Larry, thanks for the info. I just downloaded the
pdf from Dupont.
Old 03-30-2008, 08:40 PM
That stuff is not very durable.
Old 03-31-2008, 02:31 AM
What else is out there? I've did a search here and found many different ways of painting mentioned by some of the forum members, but the discussion just jumps around too much from one brand to another.
My original idea was to powdercoat the frame, but my powder coater will not do it as the inside of my 96 Impala SS frame is treated with this "black waxy" stuff and it's almost impossible to remove without having the frame dipped. He says, when the frame is brought up to tempatature the wax will melt and ruin the coating. I just cannot find a place here in VA/DC/MD area that can dip the frame.
FYI, my frame is completely sandblasted minus the inside of the frame rails.
Thanks
Ray
Old 03-31-2008, 02:36 AM
I would epoxy prime it and topcoat with single stage urethane. Pick a brand, any brand.
Larry
Old 03-31-2008, 06:14 PM
Larry
ditto that. you can add some flattener to adjust the gloss if you dont want it to shiny
Old 04-01-2008, 09:02 AM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
Actually, It works better over clean bare metal. I've sprayed gallons of it and used no primer for a lot of different projects with excellent results. It's really designed for abuse and main reason it's SO thin so's to spray into tight areas regular paints won't.
You let this paint dry properly,as it is an enamel,and it will hang with the best.
Really comes down to how "important" the project finish is and what you expect.
Old 04-01-2008, 08:38 PM
Countilaw's Avatar
Cox Custom Cars
The most durable paint that I've found for frames and that can be applied directly on bare metal is POR-15
Frank
Old 04-02-2008, 02:33 AM
Frank
Standard POR-15 or POR-15 CHASSISCOAT BLACKô?
On another project I tried the standard POR-15 on a non-rusted part and it flaked off after time. I guess it needs the "rust" to get a good bite in the substrate. No experience with the chassis stuff, but would like to here some experience if anyone on this forum has tried it.
Ray
Old 04-02-2008, 06:17 AM
I have used both the Nason chassis black. IMO fairly durable. I have also used alot of POR chassis black paint and really like it. I would still bet that epoxy with a single stage urethane would be more durable.
Old 04-03-2008, 07:22 AM
Check out Masterseries Primer and Chassis Coating... www.masterseriesct.com
Currently doing my 64 Volkswagen project. This stuff is great! I was going to go with POR-15 but had heard way too many bad experiences.
2 coats of the silver primer and one coat of the chassis black and you are good to go. You can even roll it on with a foam roller or a foam brush and it will self level leaving no streaks. Price is fantastic as well! Good Luck
From their website...
Two coats of the MasterSeries Permanent Rust Sealer Primer and one coat of AG 111 will withstand 14,000 hours of salt spray! AG 111 is also one of the most powerful anti-chemical coating systems available. AG 111 will withstand 90 days immersion in acetone.
Old 04-03-2008, 07:38 AM
68firebird
Im not a fan of POR15. I have used the chassis coat and Im not impressed with the surface finish or durability. I would follow the members that say lay a coat of epoxy primer then a single stage urethane.
Old 04-07-2008, 11:47 AM
V8 Super Beetle's Avatar
VW makes it, Chevy shakes it..
Frank
POR = Paint Over Rust! Probably not the best choice for a freshly sandblasted chassis.
From what I hear it needs the rust to grab onto or it'll peal.
Old 04-07-2008, 11:54 AM
I hear MasterSeries is good stuff for the price. I've heard the same from the VW guys whom have their share of rust problems, they say POR-15 isn't great on clean surfaces.
32 roadster chassis spark Hotrodders' Lounge 4 08-31-2007 05:06 PM
1950 Willy's wagon/panel truck chassis? ALS927 Hotrodding Basics 3 11-03-2006 03:28 PM
Anyone Painted over Blitz Black sperduton Body - Exterior 6 12-31-2005 09:53 AM
Painting roof tips needed..... Bluepen Body - Exterior 7 09-10-2005 09:26 PM
First paint scheme for '59 Caddy by me Nightrider Body - Exterior 54 07-05-2005 02:27 PM
