DuPont prep system wipes - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-08-2003, 06:32 AM
RJL's Avatar
RJL RJL is offline
I painted my 66 Mustang this past weekend. I used DuPonts NASON line from urethane primer, sealer, base and clear. During final prep, I wiped the car down with DuPont prep system wipes. They look like baby wipes. Everything was clean and tacked. The spray booth had been cleaned from top to bottom before the car and parts were brought inside. The sealer and base went down perfect. The color is Nightmist blue metallic and it looked awesome. Here is the problem, when the clear was applied lint started to pop out of the surface. You could literally watch it rise out of the clear. Aside from determining that it came from the wipes, I decided to apply 2 light coats of clear. I will let it harden for a few days, cut it with 1000 grit to get the lint out and reapply more clear. Does this sound like a good plan? Has anyone had a problem with these wipes?
Old 12-08-2003, 11:07 AM
Wiki Edits: 49
I'd give my local DuPont rep a call and ask him. I've never used them but anytime I wipe the car before painting I blow it off before actually spraying.
Be careful when sanding not to cut through to the base coat. With only two thin coats of clear it won't take much.
Centerline
http://www.hotrodsandhemis.com
Old 12-09-2003, 05:04 AM
302 Z28's Avatar
I never have used the wipes, but I have gone the traditional method of prep solvent and clean wipes. I also do a pre paint wipe with a tack rag, both on base and clear.
Vince
Old 12-15-2003, 06:34 AM
RJL's Avatar
RJL RJL is offline
Well, I wet sanded all the lint out and re-sprayed 3 coats of clear. It went down like water. I was very happy with the results. I was not happy about having to buy another gallon of clear but I only have $450 in the whole job not counting sweat equity. It looks like a pro job. I think this will be the last time I do this. Now I know why body shops are expensive. I hope to get pictures posted soon. I am pulling the whole suspension next week.
