dupont water base - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-29-2011, 02:35 PM
dupont water base
i shot the side of a ford ranger with water base black got some dirt how long do you wait to sand it out and what grit would you use,and is there another controler to use when the humidity is sky high.
Old 05-30-2011, 09:05 AM
454 Rattler's Avatar
NEVER SATISFIED !!
I can't help you but I'm sure someone will come to the rescue soon.
454 RATTLER
Old 05-30-2011, 10:59 AM
I have no knowledge about Dupont so I would say check the tech sheets, all your answers about sanding will be there.
On the humidity, that is a tough one. With the air already full of moisture, the water in the paint has no where to go. The biggest thing is air movement and heat. The air movement is tricky in that just blowing air on the surface creates a low pressure area right on the surface and the solvents (read that H2O in this case) don't get pulled out.
Running the air sideways across the surface is best. But having one of these is highly recommended for flashing waterborne.
Item on Ebay (click here)
This device makes the air "tumble" over the surface pulling the solvents out of the film.
Help with dupont chroma base Jeffrey Body - Exterior 8 10-31-2006 05:48 PM
Dupont base question hemi43 Body - Exterior 1 05-24-2006 08:39 PM
Best DuPont base??? SideSlip Body - Exterior 4 02-17-2006 12:50 PM
Drop of water in the base Scode68 Body - Exterior 7 11-29-2005 03:58 PM
Dupont Clear over metallic base dave220 Body - Exterior 5 04-01-2005 08:16 PM
