Dura Glas then epoxy
If I use 36 grit to rough up bare metal, wouldn't it be better to put the dura glas over that then spray ppg epoxy over that, or epoxy first then dura glas, if I do the dura glas over the epoxy in the time frame, what about shrinkage or solvent evaporation, I'm thinking.
36 grit bare metal dura glas epoxy wait a week then sand the epoxy with 180 or red scotch brite then evercoat filler then k-38 this is on the bottom of the floor pans because I want them perfect Any help here would really be appreciated, thank you in advance Rob http://webpages.charter.net/2manitowoc |
dura glas then epoxy
Thank you roger1, how long to wait after the epoxy is on, any shrinkage from the epoxy drying.
Rob |
Checked out your web site of cars, nice stuff you got there.
Any body else on this subject. Rob |
Dura Glas then Epoxy
Thats two and o for epoxy first, hows it going kenseth
Rob |
I filled my roof seams and a couple of deeper dents with E-C glass filler, also used some Metal to Metal filler in areas - all on bare metal. Sealed everything with epoxy, the used my Rage filler to surface, then 2K.
The only recommendation I have is loose the Duraglass. My God, that is WAY too much work. Unless you are trying to create some sort of "structual" strength or something, just use regular old filler.
Use the filler on things that need a lot of filling, sand it with 80 or even 40 so you don't have to work too hard and then polyester prime the whole shooting match. You then can sand that polyester primer to PERFECTION and have the most beautiful floor that side of the Mississippi. ![]() Brian |
Yeah, your right Brian, duraglass is a lot of work if you try sanding it, but I am assuming he is using it on a butt welded area or something similar. I always like to put fiberglass filler down first when smoothing a welded seam, of course it just hit the fiberglass with a grinder to flatten and don't really sand it unless I have to, then use plastic filler over the top and sand that. Maybe just a skim coat of fiberglass in case any little pinhole in the weld, but be neat so you don't give yourself a lot of work.
Its going good Rob, finally found a job, been there a month now and was just told I got a small raise. |
Brian, so what you're saying is put the filler over bare metal, then spray epoxy over that, then I will wait a few days then scuff the epoxy then spray k-38 then sand then paint it, this is the underbody.
Thanks Rob http://webpages.charter.net/2manitowoc |
GRN69SHV, well thats two and two epoxy first and epoxy last, hows it going. Rob
No Rob, spraying the epoxy first is going to give you the best foundation for the filler.
This is my concern with the Dynaglass. It is very hard sanding, it fills like a mutha Hubbard but sands like a brick. If you are working on what I picture it (a photo would be nice) I see lots of body lines and things that are on the typical floor to strengthen it from flexing. Sanding around that stuff is the worse, holy crap you wear your finger prints off. Regular filler like RAGE will sand much easier, if you apply the epoxy first you have a corrosion fighting base for it, then after you sand it you apply a urethane or polyester primer. AGAIN, polyester primer is for serious filling, you may not need it. But as I said, I picture this complex hand sanding around lumps and lines and brackets and such that I have on floors. If you don't have this where you are doing the actual smoothing of your weld seams, then skip the polyester primer. Just sand the filler with a finer paper, and use a urethane primer over the whole thing. Sand it all smooth and paint. If you have a lot of this hand sanding, you could save a lot of finger tips by sanding it with coarse paper (much faster cutting) and then polyester prime it, then sand that with a finer paper to paint. Or you could even just apply the polyester primer over the area where the filler is, sand it with 180, filling and surfacing all the scratches and pin holes and what not in the filler. Then urethane prime the whole thing, sand that and paint. Brian |
Thank you Brian.
Rob |
| What grit? before and after epoxy sealer ? | 67LS1T56 | Body - Exterior | 7 | 08-17-2005 10:04 PM |
| Marine Epoxy Primer? | rlackey | Body - Exterior | 10 | 03-24-2005 04:14 AM |
| Barry, epoxy adhesion testing? | baddbob | Body - Exterior | 21 | 03-20-2005 09:12 PM |
| applying epoxy - gun question | Dubz | Body - Exterior | 3 | 09-15-2004 07:02 PM |
| Urethane and Epoxy Primers | bmech211 | Body - Exterior | 1 | 04-17-2004 05:04 AM |
