-   -   Durability of a 10 bolt posi? (http://www.hotrodders.com/forum/durability-10-bolt-posi-228982.html)
snakebit68 01-30-2013 09:19 AM
I am wondering if anyone can tell me the limitations a 10 GM posi with 4.10 gears has. I've just completed a 546 HP 486 lbs of torque 383 stroker and question if the rear end I have is going to be able to handle it. Any thoughts?
BOBCRMAN@aol.com 01-30-2013 02:11 PM
There are several 10 bolt rears. What do you have?
rick 427 01-30-2013 02:26 PM
And whats it going under...car,truck,cement mixer? whats it's intentions, street,strip?.transbrake?. Is it going to see slicks?What axle's?. Is there a c-clip eliminater kit in it?
snakebit68 01-30-2013 02:47 PM
10 bolt
Its in a 91 GMC s-15 Stock rear end with posi carrier out of a 94 camaro z-28. 400 trans with 3800 stahl, 383 stroker with 546 hp
big gear head 01-30-2013 03:18 PM
Not a chance. That rear end will blow apart pretty quick if you get any traction at all.
snakebit68 01-30-2013 03:30 PM
10 bolt
Thats kinda what I was thinking. I've got an opportunity to buy a narrowed 12 bolt with 33 spline Strange axles ...ladder bars...billet yoke... aluminum cover...4.88 Richmond gears... all new for 1250.00. Good deal?
big gear head 01-30-2013 03:34 PM
Is it the right width for your truck? Do you want 4.88 gears? If it has a spool then it't not going to be worth a crap on the street. Ladder bars are noisy and stiff on the street. If it's what you want then the price isn't too bad. What are you going to do with the truck?
snakebit68 01-30-2013 04:43 PM
10 bolt
Mostly 1/4 mile passes...but a street cruise now and then
prostreet6t9 01-30-2013 06:15 PM
If thats a bolt on deal it seems pretty fair.
vinniekq2 01-30-2013 06:44 PM
Us e traction bars for a street car. A lot of people dont know how to drive with ladder bars,they are not very forgiving if you chop the throttle at high speed,especially on slicks
