duraglass the old lead seam? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-25-2010, 12:41 AM
We did a roof skin on my car and I heard of guys using duraglass to fill in where the lead once was. That's what I would like to do but just wanted to see what other guys are doing. I know we could make a strip of metal to go in there but I'd rather not
Old 06-25-2010, 11:05 AM
merlinsoars's Avatar
Sin Vertis Stratio
Any plastic will have a different coefficient of expansion than the steel under it ,the net result is it will not stay put over time.
Do it once, do it right
Old 06-25-2010, 01:28 PM
SS66chevelle's Avatar
HR VIOLATION
Just had my paint and body done by a professional muscle car resto shop (not a collision shop)
What they did was weld the crap out of the seam between the quarter and the roof skin (I replaced the quarter myself which had the sail panel on it) After welding from both sides they used the filler that has the fiberglass strands in it, and then the standard evercoat rage xtreme over that followed by the spray poly over the entire car. We discussed using lead and the guy assigned to my car (over 30 years of experience as a body man) said that with the modern improvements to filler and a properly prepped metal base, the lead was not necessary whatsoever. He said he would do it if I wanted it, but that he honestly felt that it would be a waste of my money.
That is my .02 cents based on the experience I had and based on the reputation of the shop I used, which has done some very high end very rare cars in the not to distant past.
Old 06-26-2010, 05:03 PM
While I agree that lead has its place in some areas, unless this is a high-dollar piece, or a concourse car, you really don't need it.
Properly applied, a good quality plastic filler will not fail. The stuff holds up.
I would suggest that if it's an area where there can be movement (like where the seam from two halves of a hood come together or an edge of some kind, like where a scoop was molded on), use some fiberglass cloth and resin first. I know the Duraglas has chopped fibers in it, but sometimes a little extra insurance can't hurt.
Not on a car....but there is a glob of bondo still stuck on the concrete footer of my mother's garage...that I slung there about 48 years ago! It's exposed to the Ohio weather, unpainted, unprotected. Yep.
Voting Starts Now May Hotrodders,com Art Contest "50's Lead Sleds" Anything Goes Only Racing Hot Rod Art 26 06-03-2010 06:40 PM
Lead or plastic to fill seam ending at sharp corner? ka24deroadster Body - Exterior 11 02-21-2009 11:23 AM
back side of a welded seam modas Garage - Tools 3 01-08-2007 12:23 PM
The death of conventional hotrodding - alternative power Mad Maggot Hotrodders' Lounge 57 01-23-2006 11:51 AM
37 Ford lead seam help needed tnfarm Body - Exterior 3 11-29-2005 03:01 PM
