Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Duraspark module overheated and engine died
Old 10-27-2012, 10:09 PM
Augusto's Avatar
Augusto Augusto is offline
From the middle of the world
Last wiki edit: How to rebuild an engine Last photo:
My points to electronic conversion suffered this problem, just started, set the timing and was idling, like ten minutes or more, suddendly the engine died, no spark, inmediately I noticed the module was very hot, so was the ignition coil, it's a TFI "square" coil from a 1987 Econoline I6, the module is a new Spartan brand name blue module.
I cooled the module with a wet rag and the engine came back to life.
I hooked up the module and the coil with full 12V, no ballast resistance for the coil, I'm feeling this is the problem, maybe this coil needed a ballast resistor ?
I have this 1.6 ohmm ballast, if I install this, will the coil run cooler and put less strain in the module, so it won't overheat? or the TFI coil is wrong for the Duraspark ? it was running fine with the points, never missed a beat, never tested how hot it run with the points though, but I did used the ballast resistor with the points.
thanks.
