PROBLEM SOLVED
the new coil works perfect, module stays cool, coil slightly warm as expected.
engine starts fine with the initial timing set at 20 degrees.
the TFI coil draws more current than the module can handle, that was the problem.
thanks for helping.
greetings from the middle of the earth.
