I have a complete '75 Lincoln 460, a new blue strain modual and enough of the orig harness to make a new DS harness.. Would this operate better than a new aftermarket small cap HEI?
This is a corvair site, but the info on ignitions applies to anything. Its good reading. I read it all the time as I am having trouble wraping my head around it. http://autoxer.skiblack.com/rayignition.html
It explains a lot.
I think a gm systemis better than the motorcraft duraspark, you will see what I mean when you read the article.
Both of the systems - the HEI set-up and the Duraspark II have their advantages.
The HEI will definitely operate a "hotter" coil and make more spark "upstairs". It varies the "dwell" (coil charging time) based on AMPS - heating of the grounding transistor. Will go down to 15° near idle - and up to 35° at higher revs - its a nice design.
The Durapsrk II has fixed electronic dwell -about 26° - stays there as the revs go up. It basically duplicates a single point distributor charging the coil. The grounding transistor won't handle the AMPs of a really "hot" coil with low primary resistance. Has a better spark than the HEI at very low revs due to the greater dwell. A really good feature - if you fully wire it in, it monitors the operation of the starter solenoid and retards the spark 6° for starting. If you wire the solenoid detector wire (the white one) to switched (on-off) 12 volts, it will allow manual selection of the 6° retard on command.
Matt - do a Google search "Converting a duraspark ignition to HEI". You can easily use the cheaper GM module, even mount it in a gutted Ford module and they work well according to some other folks. Until the current car have always just used the Dura Spark and never had a failure - ever.
I run a Duraspark distributor with the later Ford high energy coil from an efi and use the GM module. I like that set up real well. Plus it is junkyard cheap. Just remember to put the module on a heat sink. I did mine on a 92 F-250 and just modified the original heat sink that is mounted on the inner fender. I know another guy who modified an aluminum head off a Briggs and Stratton for a cool finned heat sink.
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
