Dust boots for Heidts ball joints - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-23-2012, 10:47 AM
This is some info I am passing on about rubber dust boots on the Heidts upper and lower control arms. I purchased upper and lower arms from Heidts that came with my new chassis Engineering front end, the dust boots that were supplied (purchased this in March 2010) with it were too large and allowed water in the upper boot. I read some where about Energy Suspension part # 5.13102G and purchased these from Summit their # is ENS-5-13102G at cost of $9.99 . This provides four dust boots . Two boots have thicker ring on top I installed these on bottom control arms. These work really well and retain the grease and keep water out.
I called Heidts and gave them the above info but do not know if they changed out the ones they were supplying with the control arms to the ones mentioned above. Thank you Victor
new ball joint boots cracked tech69 Suspension - Brakes - Steering 6 05-01-2011 09:25 AM
FYI. removing ball joints in Heidts A arms powerrodsmike Suspension - Brakes - Steering 5 11-11-2007 09:41 AM
Ball Joints....not a hot rod but.... screamin340 Suspension - Brakes - Steering 7 08-05-2005 03:51 PM
Mustang II ball joint boots jaxhome Suspension - Brakes - Steering 24 04-04-2005 07:35 AM
upper ball joint boots yezek6 Suspension - Brakes - Steering 3 03-29-2005 04:25 PM
