dust collectors - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-15-2004, 07:53 AM
Last journal entry: PICTURE TEST
dust collectors
What is everybody using on there glass beading cabinets for dust collecors???? I have a shop vac now and it does very little. I was looking into one like they use in wood shops but, someone told me that they are different form the ones needed on a glassbead cabinet??? is this true
Thanks keith
Old 04-15-2004, 08:03 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Your problem is not enough volume in your vac. A large 'wood shop' type like the one I built for my shop would do the job. Mine has a 1 1/2hp motor and moves a lot of air. Haven't tried it on a blasting cabinet but it doesn't even raise a sweat keeping up with my 6" jointer or my 12" planer. Does a super job taking out large and fine dust. I don't even run a final filter just let the vortex do all the work. I got the plans for mine from WOOD magazine a few years ago.
Old 04-18-2004, 02:40 AM
deuce_454's Avatar
i think you are right in that they are different. the big cone shaped shiny thing in willys picture is called a cyclone, it seperates dust and debree from air by spinning the air in the cylindrical part of the cyclone. the size and weight of particle that needs to be seperated determines the physical size of the cyclone and since wood shavings and wood dust has more volume per weight than fine glass bead dust the cyclone is different. you can even mount one in your diesels exhaust to remove the particles. as a rule of thumb; the smaller particle you want to seperate the higher the g-force in the cyclone...
Old 04-18-2004, 11:45 PM
Wiki Edits: 21
Actually since the sand is much higher density than wood shavings, the cyclone separator will work on it better than wood, taking out even smaller particles of silica.
Old 04-19-2004, 02:21 AM
FASTCHEVY's Avatar
RatRod B4 RatRods were Cool
Man that's pretty cool Willys. Good thing I don't live close to you, or you would never get rid of me. lol
Old 04-19-2004, 01:49 PM
Wiki Edits: 21
Actually, if you did live near me I WOULD get rid of you in my extremely messy shop! Still have a few small children unaccounted for who ventured into there and haven't been seen since!
