30 degrees is correct. Be sure the cylinder selector is set on 8, not 6 or 4. The gap should be around 0.017" (a little wider if new points), so the gap should be very close to this when the dwell is correct.
Changing the points dwell/gap also changes the timing a small amount. Be sure to recheck the timing after setting your points. It's always a good idea to use a soft cloth w/lacquer thinner or acetone to remove the preservative from the points faces before using. It's NOT a good idea to file points, regardless of what you may have read. Always replace the points and condenser as a set. |
Sounds like the points cam is worn.
Fact is stranger than Fiction |
Thanks for the reply and the help. The rebuilt distributor I got had a bad set of points in it. After 2 days of working on it, the sun was just at the right spot and I seen the set screw wobble. At 30 degrees the screw was loose and the points jumped all over the place. At 18 degrees the screw was a little tighter and kinda held the points a tad better. New points and the world is a nice place again.
I'm a couple years older than you and remember the old points dist....but I'm just curious......Why??? The stock and after market HEI's are sooooo much better than any points dist.
Mornin 327NUT,
I had the hei setup in it but it was hitting the fire wall and it keep moving on me. The smaller hei distributor is $400. I went back to old school points and dist. for $140. Besides, I now have use for my old dwell meter. But now that I have it runnin again, I found this. Oh well, it's just money. |
| The Following User Says Thank You to cobalt327 For This Useful Post: | ||
hobbles (07-07-2012) | ||
One thing I just found out, I had it settin at an idle for 1/2 hour and with my 185 thermostat in it and the temp gage only went up 1/2 way with the points, not the 3/4 it did with the hei in it. No biggie, just a fact.
Good Grief cobalt327, where the heck were you 3 weeks ago?????
That is a GREAT site you posted. I bookmarked it. I will now need ANOTHER set of spark plug wires. Oh well, again,, it's only money.. Thank you!! |
No cobalt327, The timing was set at 10 degrees, same as now.
Good mornin' back...... if you ever build an odd ball and want a small cap HEI here's the one I had built by "Dave's Small Cap HEI's". Just send him your old points type dist. and he'll convert it for around $275....being different costs more, the MSD cap is $40 more but it looks "Hot Rod" and it's worth it. This started life as a '70 Cadillac El Dorado dist. and now it's all modernized and a helluva lot smaller than that giant, ugly. stock HEI. This is the 4th one I've had done from Dave's and they work great.
| Tags |
| dwell, points |
| 350 small block chevy setting dwell and timming | Jeff J | Hotrodding Basics | 5 | 07-30-2010 09:13 AM |
| Question on setting pressure on HVLP | danny_g | Body - Exterior | 6 | 09-03-2009 04:24 PM |
| need to know dwell setting | bigrobdog | Engine | 3 | 07-28-2009 05:23 PM |
| Question about setting valve lash.... | Trans Am Tony | Engine | 3 | 05-22-2007 04:57 PM |
| Need help with setting timing & dwell | m41lion | Electrical | 2 | 12-01-2005 03:01 PM |
