Dying Door Panels? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-25-2010, 08:20 PM
Dying Door Panels?
I'd like to dye my 64 Pontiac door panels Dark Blue to match my new seats, They are dark and medium blue now.. Is this hard to do?
I have 63 GP door panels in there now and the pattern doesn't match the seat pattern...
Thank you,
Jeff
Name:	Door panel Bonne.jpg
ID:	49223   Click image for larger version
Name:	door panels Bonneville 004.jpg
ID:	49224   Click image for larger version
Old 10-25-2010, 08:29 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
No it's not all that hard to do if you use a good product, But the main thing is to make real sure they are properly cleaned and wiped down and dry before you start . JMO
Cole
Old 10-26-2010, 06:43 AM
DanTwoLakes's Avatar
Wiki Edits: 22
This is the perfect place to use SEM products. You can use aerosols and get great results. You will need to use their cleaner, (SEM soap), their vinyl prep, and possibly their adhesion promoter. It is easy, and if you take your time it will look great. Here's a link that tells you exactly how to do it: CLICK HERE Here's a place online to buy what you need: CLICK HERE
When you spray this stuff on, it gets absorbed into the vinyl, it doesn't sit on the surface. It will look like it came that way when you're done.
Old 10-26-2010, 07:53 AM
001mustang's Avatar
I used rattle can vinyl dye years ago on my mustang w/ no problems.
Some will color match vinyl dye.
Only concern would be removing all silicone.
I never use silicone products on my paint or vinyl.
Old 10-26-2010, 03:59 PM
Thanks for the responses guys...
Dan, I'm going to try that SEM kit... Can they get a close match to my seat vinyl color? It don't have to be perfect, I'm looking for a dark blue...
Old 10-26-2010, 06:08 PM
Wiki Edits: 22
If you send Thad and Donna at Vinyl Pro a sample of the fabric, they can match it exactly and put it in aerosol cans for you. Call them first and tell them what you want. If you have spray equipment, they can mix a quart or whatever you need. That would be cheaper than custom aerosols. There should be a dark blue that you can use. Classic Coat navy, #17193, or Color Coat #15043 Shadow blue should both work.
Old 10-26-2010, 07:28 PM
Thanks Dan, I have there link and will order from them..
dying seats and carpets dusterbd Interior 5 11-19-2009 04:30 PM
battery dying lemans'n'gal Electrical 2 04-14-2009 09:49 AM
Dying Cad? OneMoreTime Engine 6 11-17-2005 05:14 PM
84 S-15 keeps dying lonewolf3197 Engine 4 01-12-2005 11:13 AM
Are machine shops dying off? Jmark Engine 32 09-12-2003 05:36 PM
