Dynamat vs.Lowes "peel and seal"
I am looking for a solution to making my musclecar quieter inside(not outside LOL) Dynamat is pricey and I saw somewhere there was talk about using peel and seal from lowes ( a fraction of the cost)
Has anyone used this and what was the results. Are you satisfied?would you do something different? Anyone have a different suggestion? Thanks |
I used two types, a foil encapsulated foam called EZ Cool from LoBucRod on the open flat areas of the interior http://www.lobucrod.com/ and B-Quiet which is like a Dynamat product inside the doors http://www.b-quiet.com/testimonials.html. If you read the EZ Cool data they specifically say that this is not the foil bubble wrap from the hardware store. The foil/foam is installed with spray contact cement, and the B-Quiet is peel & stick.
Peel& Seal is an asphalt based roofing product, and Dynamat is butyl based sound deadener. While they look a lot alike, they are not the same thing. You have to look at the specs for each one to do a proper comparison. I personally think Dynamat is over priced, and rspears has found some of the better alternatives.
__________________________________ No one lives forever, the trick is creating something that will. __________________________________ Last edited by DanTwoLakes; 07-02-2011 at 08:51 PM. |
i have used the B-quiet product. Peel n stick product on my 1961 Dodge Lancer. After about 7 yrs a few edges were lifting slightly
Also used it on a stainless steel sink for the kitchen. The B-quiet really reduced the sink noise when the disposal was running
At the Bonneville Salt Flats, first gear is known as 130 mph. |
Best price I found on the stuff
http://www.amazon.com/Dynamat-10455-...sr=1-1-catcorr it is the same bulk pack less Chips face and hype on the cover check the details. Dynamat in a plain box. |
I used the "Peel & Seal" on my Maverick, works great! The only downside I can see is if it ever needs to be removed it will require a ton of work to get it off...
Russ |
The problem with peal and seal is that it is not designed for vertical surfaces. If you use it on doors or the roof the sun's heat will soften the asphalt adhesive and it will eventually fail. I suppose you could use it on the floor without too many problems but there is no way I would use it on vertical surfaces at all. The butyl based stuff won't soften so much in the heat and is in the end a much better, although much more expensive choice.
Centerline HotRodsAndHemis.com Never pick a fight with an old man. If he is too old to fight, he'll just shoot you. - Anonymous |
Thanks centerline, I have not made my choice, but it wont be peal and seal, thats for sure. |
Think about it. Peel and Seal is intended to be used on the roof of a building with support underneath it. Just like Centerline said, it is not intended to be used on vertical surfaces, or worse, overhead with no support under it at all. I would think in a hot climate it would be a terrible choice. Remember, these products are intended to be used for sound deadening, not for heat resistance. None of the products mentioned say they are solely for heat resistance. Heat resistance, if it happens at all, is an afterthought, not the main intention of any of these products.
__________________________________ No one lives forever, the trick is creating something that will. __________________________________ |
Exactly Dan , that is why I asked. I saw posts pro and con. I was trying to figure out if it is a good Idea, doesnt appear to be.I wont be using it.
rs spears suggested E Z cool. I am leaning real hard in that direction. |
![]() i know this has come up before, if you search it there will be some good reading |
how about fatmat
I used the DynaMat
IMHO ... it works great and it worth the $$$. ![]() I also used Lizard Skin. ![]() The DynaMat works great for the sound and heat and the Lizard Skin is for the heat. Lizard Skin also has a sound formula. ![]() It gets HOT here in the HOT, HUMID South ... and I wanted the 32 3W quiet and COOL inside. I have the DynaMat and the Lizard Skin everywhere. The roof, the doors, the floors and even the trunk area. The 3W is quiet and is easy to cool with the Vintage Air Generation Mini II Go here for the Lizard Skin info web page http://www.lizardskin.com/ Disclaimer : I am not affiliated with or connected to Lizard Skin in any way ... I am just a satisfied, happy customer
"I won't be wronged . I won't be insulted, and I won't be laid a hand on. " |
| Recent Interior posts with photos |
| Currently Active Users Viewing This Thread: 7 (0 members and 7 guests) | |
| Strange thing happening with my clear "solvent pop"/"fish eyes" ? | myfamiliacc | Body - Exterior | 35 | 02-16-2013 07:18 PM |
| Covering stock "plastic" door panels with "vinyl" | csilva84 | Interior | 1 | 10-05-2007 06:30 PM |
| wiki pages: "How to rebuild an engine", "Window removal/installation" | Jon | Hotrodders' Lounge | 0 | 07-11-2006 12:44 PM |
| I need the '"Peel and Seal" Home Depot link that someone posted!!! | hemi43 | Interior | 3 | 03-09-2005 06:48 AM |
| Hey croz look """"IMPORTS SUCK""" | 78 monte | Hotrodders' Lounge | 14 | 08-30-2002 01:13 PM |
