Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - dynamic compression
Old 06-24-2004, 07:18 AM
mstngjoe's Avatar
mstngjoe mstngjoe is offline
Computing the DCR is done basically the same way as computing static compression. The difference being that you need to know the position of the piston in the cylinder bore at the point the intake valve closes.
Here's a link with some more detailed info:
http://webpages.charter.net/darrell1/dynamiccr.htm
