Dynamic Compression - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-19-2006, 03:11 PM
Dynamic Compression
Hi, I was just wondering what would be a target dynamic compression ratio to shoot for with both cast iron and aluminum heads for 87 and 92 octane. If anyone has any suggestions I would appreciate it. Thanks,Don
Old 05-21-2006, 03:12 PM
Old Yeller 1970's Avatar
Loud Pipes Save Lives
Chevy Hi Performance had something on this a few years back. They were building an angine with 8.7:1 compression and Vortec heads with a 268 Comp Cam. It made good hp on the dyno but after they got it in the car it was a slug coming off the line. They diagnosed the problem as being to low on the dynamic compression. I think they said it was around 120 PSI. I believe they said not to go over 180 and 160 was about optimal. But I'm only going from memory and that was at least 4 years ago.
I've never been able to find any more on it since. It seems to me that knowing the dynamic compression is a great way to build an engine because it takes the guess work out of trying to figure the right camshaft vs Static Compresion Ratio. But most people just figure a certain amount of increase in the staice comp. ratio based on how large the cam is and what size engine it's going into.
Old 05-21-2006, 09:21 PM
Thanks for the reply. I heard that around 8 to 8.25 to 1 is what the dynamic compression should be, but I don't know if that is for cast iron heads or aluminum.
Old 05-22-2006, 05:52 AM
OK, what I was talking about was dynamic cranking pressure. I'm not sure what the dynamic compression ratio is supposed to be but I found a website with a calculator that might be able to help. However, it requires a subscription to their website.
http://www.smokemup.com/auto_math/dy...sion_ratio.php
Old 05-22-2006, 01:11 PM
KB Pistons has a dynamic compression calculator website that doesn't require a membership.
http://kb-silvolite.com/calc.php
There is no set number for DC on pump gas. Way too many variables.
Compression question for the Pro engine builders.. Axelrod Engine 14 01-16-2007 10:29 AM
351 windsor running rich ???? ve3ham Engine 19 08-08-2005 12:48 PM
11:1 CR run with 91 pump gaz???? Ratoflic Engine 56 07-29-2005 07:53 AM
dynamic compression k-star Engine 8 06-25-2004 09:33 AM
camshaft selection and dynamic compression blndweasel Engine 7 03-13-2004 07:19 AM
