Dynamic Compression Ratio??
Having searched and found the calculations for both static and dynamic compression ratio, I see how the choices I make will affect compression ratio. I still would like to know (in general terms) what is the target number for dynamic compression ratio?Based on what I've seen there is a wide range of claims being made on what static compression ratio you can run on xx octane, but the real measure is dynamic compression ratio. I've been around for a while and know in general what is too much static compression ratio, but how do I correlate static numbers to dynamic numbers?
For my application I am building a bbc for street performance use, I will run a stock TH400 with 3.73 gears in a 3600lb car. |
Maybe this will help, most of these guys are members over at Chevy Talk and are pretty reliable.
DCR Combinations |
Thanks for the replys. I'm in the planning/purchasing stages and I want to know that once I make my head and piston choices I can live with them.
| 383 Chevy Compression Ratio? | Skunk | Engine | 5 | 07-06-2005 07:07 AM |
| 327 compression ratio | dadsgp | Engine | 4 | 06-23-2005 08:42 PM |
| Compression Ratio with 64 cc heads & Federal Mogul Sterling 345np | Houman SS '70 | Engine | 9 | 05-01-2005 11:42 AM |
| compression ratio? HP,Torque ?? | J327HO | Engine | 12 | 10-20-2004 10:11 PM |
| Compression ratio | dubie | Engine | 3 | 06-25-2004 08:50 AM |
