dynamic compression and regular gas
working through some compression numbers, using the Pat Kelly Compression calculator and I have a question or 2
Engine build is a slant six, 2bbl carb, free flowing exhaust, OS valves, mild porting,staying hydraulic cam, will have 250/260 duration, .441/.443 lift, 45 degrees overlap on 105 lSA Vehicle is a 83 D-150, short bed, a833 want a low RPM torque motor and want to stay with regular gas. cc's heads and checked piston recession on stock motor and using the PK calculator got static 7.97 dynamic 7.31 had recently checked cylinder compression, those numbers were 128 to 150 using the cam mentioned above and shaving the head / block .100 to raise compression and re running the numbers in the PK calculator I got static 9.3 dynamic 8.3 using the cam mentioned above and shaving the block / head .080 to raise compression and running the numbers again I got static 9.06 dynamic 8.03 I had found a posting on this forum where it was stated 8 to 9 dynamic compression is idea, 8 favoring the street and regular gas, 9 favoring high performance street and premium gas. I am wanting to stay with regular,, any thoughts on if the .100 shave is too much or the .080 will leave something to be desired? had also found a posting here that said Static Cranking Pressure Performance Implications Less than 115 PSI Poor low speed performance, poor throttle response, hard starting. Compression Ratio and Cam not matched or worn rings, valves. 120 PSI to 145 PSI Expected range for most stock or modified street motors. This is a good range for a street motor. 145 PSI to 165 PSI Modified street motors. Static pressures in this range should produce good results. This is a good range for a street motor. 165 PSI to 180 PSI Marginal for street motors. Possible hard starting, detonation and overheating. Over 180 PSI These are all out race engines. A street motor in this range will be trouble. Stick to the track. so is using dynamic compression * standard air pressure of 14.7 psi accurate to predict cranking cylinder pressure?,, with my calculated dynamic in the stock build of 7.3 * 14.7 should have got around 107,, my results were much better. In the 130 to 150 range. thanks |
obviously not for a dog that can't comprehend this
so is using dynamic compression * standard air pressure of 14.7 psi accurate to predict cranking cylinder pressure?,, with my calculated dynamic in the stock build of 7.3 * 14.7 should have got around 107,, my results were much better. In the 130 to 150 range |
both answers were helpful,,thanks
for cranking compression,found these general guide lines
Anything under 100 psi = rebuild the engine. 100 to 140 psi use 87 octane 140 to 170 psi use Premium (92 octane) 170 to 200 psi use Race gas (100+ octane) 200 to 240 psi use Super Race Gas (114) 240+ alcohol also found this calculator that converts dynamic compression to cranking compression, and is correctable for altitude http://www.rbracing-rsr.com/comprAdvHD.htm regards DT |
Thanks for the psi guide! That will come in quite handy while doing compression checks. |
| regular or hi volume oil pump? | kunkle | Engine | 3 | 02-05-2009 09:18 PM |
| Flatbed Vs. Regular bed. | chevykid33 | Body - Exterior | 3 | 01-16-2008 07:23 PM |
| Regular or synthetic? | byrdta76 | Engine | 10 | 06-14-2006 12:26 PM |
| Synthetic Oil vs. regular oil | juiced66malibu | Engine | 18 | 12-30-2005 10:03 PM |
| RV cam or regular hiperf. cam | 72 Z28 | Engine | 4 | 12-15-2002 05:50 AM |
