Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Dynatron Ultralite Body Filler doesnt cure?
  #34 (permalink)
Old 11-24-2011, 04:41 PM
NEW INTERIORS NEW INTERIORS is offline
life is a temporary assignment
Originally Posted by TucsonJay
I don't know if you do any fiberglass work, but most resins are what they call "air-inhibited". The reason for that is so you can add more resin on top without sanding... and it will bond chemically.
Body fillers use a fiberglass-type resin with filler added. I suspect they all have a surface that dries more slowly for exactly the same reason.
I haven't used all brands (obviously) but the difference may be that some are prone to dry more slowly, due to differences in the formulas. Cold weather, of course, would slow it down even more.
If it's a small area, you might try a heat lamp... but don't get it too hot!
Over Five day's at 90* is a long time to sit and wait... I wonder how many more days it will take...
The reason you can glass over that glass ,,Is because it doesn't have wax added..The one with the wax added you will have to sand in between layers..
