Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Dynatron Ultralite Body Filler doesnt cure?
  #35 (permalink)
Old 11-24-2011, 08:59 PM
lets cut it up's Avatar
lets cut it up lets cut it up is offline
I use body fillers every day...in fact we have been tring different ones because it seems the formulas seem to be changing as the rage I used years ago acted tolaly different than the one I buy now. I find that most of the fillers stay somewhat tacky untill you cut the top layer. Yes it clogs paper. The thing that I noticed is the different brands do it differently. Now if you dont mix up the filler before you add hardener you will have some problems drying also.I put mine on a shaker then let it settle. Metal glaze is also bad for tackyness after drying. By the way people, 3m owns evercoat so dont think your getting something different with evercoat products!!As far as fiberglass resin goes..it wont cure if there is oxygen present hence the wax additive if your not going over it again with glass.
