Dyno sheet... - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-18-2011, 08:39 PM
1bad32's Avatar
Dyno sheet...
Here's the dyno sheet for My 383sbc w/ 6-71 blower.
Crazzzzy hp for My '32 coupe.{almost 615 hp}
How do the #'s look?
Old 11-18-2011, 09:36 PM
bentwings's Avatar
bentwings
That's pretty stout!!! If you can get it hooked to the ground it will be barnburner.
Keep us updated.
Old 11-18-2011, 10:21 PM
Siggy_Freud's Avatar
Looks nice, but do you have one with the RPM line on the bottom?
Bringing history and technology together.
Old 11-18-2011, 10:31 PM
WDCreech's Avatar
Grumpy Old Goat Herder
That chart is B.S. Horsepower and torque ALWAYS intersect at 5250 rpm. This shows it at about 4750.
Old 11-18-2011, 10:33 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
RPM is green line, looks like test was run between 4K and about 6225 RPM.
Now, why the TQ and HP didn't cross until about 5600 RPM instead of 5250 RPM I couldn't say...
Old 11-18-2011, 10:46 PM
WDCreech's Avatar
According to what is printed on the chart, blue is torque and red is horsepower. Those lines intersect at about 4750 rpm.
Old 11-18-2011, 11:08 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Nah. Look again.
Old 11-18-2011, 11:13 PM
WDCreech's Avatar
I'll stick by what I said. Maybe you need to take a second look, sir!
Old 11-18-2011, 11:17 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Sir??
Anyway, RPM is the far right vertical line marked "All Other Lines". The horizontal line across the bottom is "Run Time (Sec)" only.
Otherwise, using the bottom horizontal Run Time line (the only place I see where you could get your numbers from), it's making 430 HP/560 TQ at 0 RPM and the peak power would be at about 8700 RPM. The peak's stated to be at 6226 RPM...
MAIN point is, the lines do not cross at 5250.
Old 11-19-2011, 08:10 AM
Yeah, would be nice to see it though in a conventional format, starting from a lower RPM. Don't get me wrong, nice numbers! But if it were me, I'd like to see some in the RPM ranges I use 90% of the time .
Old 11-19-2011, 08:55 AM
1bad32's Avatar
I will look into that and ask the engine builder!!!
Old 11-19-2011, 12:00 PM
WDCreech's Avatar
Originally Posted by cobalt327
Sir??
You are correct! I was reading it like it was a normal graph with the RPMs across the bottom. Anyway, it's hokey.
Old 11-19-2011, 12:37 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I agree w/you.
Old 11-19-2011, 12:56 PM
1bad32's Avatar
So what do You want Me to ask the Guy Who I bought the engine from when I call Him Monday morning????
Let Me know "exactly" so He can give Me answers to Your negative feelings about His dyno sheet.
I bought it from Big Al's toy box,,,,do You think He's a scam artist???????
Old 11-19-2011, 01:11 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
It may be something that is easily explained, and I don't think he's necessarily scamming you, but the question I would have is:
1. Why don't the torque and HP lines cross at 5250 RPM like every other dyno graph? (The formula for HP is TQ x HP divided by 5250. All this means is the lines cross at 5250 RPM)
2. Can a dyno sheet be supplied that has the power from the lowest RPM the engine will pull from, up to max power or redline, with the graph showing RPM across the bottom? (The lowest RPM is usually around 2000-3000 up to where the power falls off or the redline is reached)
EXAMPLES:
The printout can be configured in many different ways. The configurations in the examples above are the more common ones used (they both show TWO pulls on the same graph).
They show the full power curve with HP, TQ, and RPM. Simple and easy to read.
Lets see your dyno sheet! ChevelleSS General Rodding Tech 24 10-08-2012 02:27 PM
Engine dyno to chassis dyno numbers dedub Engine 3 06-19-2011 07:56 PM
Build Sheet S10 Racer Engine 1 12-20-2007 07:01 AM
Engine dyno sheet, timing? jigga99 Engine 3 08-29-2006 12:37 PM
sheet metal help?? gmthomas44 Hotrodders' Lounge 2 09-17-2002 09:53 AM
