On Dyno Tommorow..Anyone Want to Guess number?? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-15-2011, 06:31 PM
deckofficer's Avatar
Last wiki edit: List of hotrodding forums
Last journal entry: Trans swap
Wiki Edits: 12
Well, what did it pull at 5000? My torque built 383 has its hp falling off at just 4050 rpms.
Bob
  #17 (permalink)
Old 01-15-2011, 07:27 PM
obengston's Avatar
USMC
I'm not to sure mid 300 I think. All I know is he said that he feels it should be around 400, but.. we will see.
  #18 (permalink)
Old 01-15-2011, 07:46 PM
Wiki Edits: 12
Good to hear, if you hit 350 hp @ 5000, you already exceeded my guess by 5 hp and I think your motor will keep producing more power for at least another 900 rpms. My guess of your torque might be close.
Bob
  #19 (permalink)
Old 01-17-2011, 08:54 AM
obengston's Avatar
USMC
Well I'm thinking I will have the numbers to post this week or 1st part of next week. I don't think I will be where I would like to be, but are we ever there.....lol
  #20 (permalink)
Old 02-26-2011, 05:29 PM
obengston's Avatar
USMC
Sorry, its been so long, but had to go on a short deployment. So I have not been able to make it back to the dyno guy. Maybe soon. I did go to the track today. I ran a 11.7. I was spinning coming off the line and was not hitting my shift at the right times. It will take me some time to dial it in, but I feel I can easily run low 11s.
  #21 (permalink)
Old 02-26-2011, 05:46 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Two questions- what are the cam duration specs at 0.050" and what vehicle is the engine in?
  #22 (permalink)
Old 02-26-2011, 06:00 PM
obengston's Avatar
USMC
Well the car is a 68 Camaro wgt is 3400 with out me. As far as the cam specs... Allot of controversy on that. The guy I had assemble my engine, I also had him order me a custum gind. He swears the duration at 50 is INT: .288 EXH: .292. I ask him many times to make sure that was not advertised duration and he said no it was at 50. So I have my doubts.
  #23 (permalink)
Old 02-26-2011, 06:12 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
That would be a hell of a cam. BTW, the specs for duration are in degrees, as in 288 intake and 292 exhaust.
A cam w/that much duration wouldn't be able to use an ignition timing curve per se, most likely you'd need to lock it in at the total advance, possible using a vacuum advance and a timing retard (or separate starter and ignition switches) to allow it to start when hot w/o kicking back or dragging the starter.
There wouldn't be enough vacuum for power brakes and it would be idling above 1000 RPM. The idle would be decidedly rough. Not just some lope- I mean ROUGH.
This sound like what you have?
  #24 (permalink)
Old 02-26-2011, 06:19 PM
obengston's Avatar
USMC
Not exactly lol. I didn't have to much vac so I did away with the power brakes and went with hydro. The timing is set at about 19-20 initial with total right now at about 36. Idles at about 8-900. I quess the only way I will ever know is buy another one that way I can have it... Anyway I ask him so many times, and he said that it was basicall a race cam that was based off a 700 lift, but custum downed for what I wanted.. what ever that meant. I quess I need to put more pressure on him to call the guy while I'm there and ask him.
  #25 (permalink)
Old 02-26-2011, 06:23 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Well, whatever you DO have for a cam, the engine seems to like it, you're not going to run those numbers traction limited, unless the engine is making some pretty serious power for a streetable combo.
Do you know the MPH?
  #26 (permalink)
Old 02-26-2011, 06:29 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Using the 11.7 ET and guessing the speed to be 124 MPH, the Wallace calculator says:
Your HP computed from your vehicle ET is 377.62 rear wheel HP and 419.57 flywheel HP.
Your HP computed from your vehicle MPH is 467.22 rear wheel HP and 519.13 flywheel HP.
120 MPH:
402.63 rear wheel HP and 447.36 flywheel HP
  #27 (permalink)
Old 02-26-2011, 06:34 PM
001mustang's Avatar
why not use dial indicator and degree wheel to map your actual lift?
  #28 (permalink)
Old 02-26-2011, 06:41 PM
obengston's Avatar
USMC
60' 1.6858
330' 4.8579
1/8 7.4958 92 mph
1/4 112 mph
I was also shifting at the wrong time and was spinning hard would let up then smash the gas again. I have to get use to it, and get it dialed in better, but I think I can easily hit lower 11s.
Don't know how to use the dial to figure the duration out...
  #29 (permalink)
Old 02-26-2011, 06:42 PM
obengston's Avatar
USMC
My lift is 600
  #30 (permalink)
Old 02-26-2011, 06:47 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Using 11.7 ET and 112 MPH:
Your HP computed from your vehicle MPH is 344.28 rear wheel HP and 382.53 flywheel HP.
I'd guess your RWHP would be somewhere close to 400 HP, w/all the spinning and shift probs. Hard to really say until you sort things out, preferably at the track w/good tires so traction is much less of an issue. Then the 1/4 mile top speed and the weight will get you a good estimation.
69 Nova 454 going on dyno lets hear your guess tjpounder Hotrodding Basics 45 06-15-2010 08:26 PM
hp guess, anyone with a pc dyno dejo Engine 14 11-22-2006 04:49 PM
vin number or serial number rudy ballesteros Introduce Yourself 1 05-16-2006 10:27 PM
I guess I'm new too =) crashtestjoey Introduce Yourself 4 06-22-2004 05:24 PM
