Dyno'd my first motor build and numbers are much lower than expected. Need help.
Fresh 350 non roller block
.030 over
flat top hyper pistons
vortec heads 3 angle cut
Complete Comp Cam kit Hydraulic Flat Tappet 262/270, Lift .462/.469 w.springs and lifters
New edlebrock intake
HEI Dist
4 barrel
Did 4 passes on dyno and max power we could get was 240hp 288 torque. Timing set to 14 and water temp 185, air ratio was 14ish.
Do these numbers seem correct?
.030 over
HEI Dist
4 barrel
