Start a tech article on any subject...
...hundreds of hotrodders help build it into a comprehensive resource.
Fresh wiki articles that you can add to: Air suspension on a front solid axle, Basic stuff for newbies, Building a new shop, Ceramic insulation, Electric fuel pump mount, Engine and transmission mounts, Freeing a stuck engine, Gasser, How to check driveline angle, How to make a vacuum power brake bleeder, How to safely cut steel with a torch, Improving fuel economy, Narrowing a rearend, Patching a body panel, Quick-disconnect rear mount battery, Reducing vehicle weight, Stereo installation, Stripping paint, Valve spring setup, and many more...
Or, start a new article.
Hotrodders Bulletin Board > Tech Help > General Rodding Tech
  #1
Old 01-05-2007, 12:03 PM
red_rider52's Avatar
red_rider52 red_rider52 is offline
DriveItLikeItsSupostToBeD riven
Dynomax Ultra-Flow SS?
I was looking at mufflers and came across the Dynomax Ultra-Flow SS mufflers. I keep hearing how glasspack (cherry bomb) mufflers don't flow well at all. To me these Dynomax mufflers have the same basic strait though design. Just wondering what would be different and make them flow so much better? Whats your opinion on these?
Size:  17.4 KB  Click image for larger version
Old 01-07-2007, 05:39 PM
xntrik's Avatar
xntrik xntrik is offline
Save a horse, Ride a Cowboy.
re: Dynomax Ultra-Flow SS?
It's the expansion chamber that influences the pressure drop. Glass packs have a tiny expansion chamber.
A 2 1/2 inch glass pack usually is less than 2" in diameter inside with louvers. Many 2+ inch inlets are only 1 1/2 inside diameter.
The muffler you show is straight through the same diameter ,or even larger, with holes in it, not louvers.
It also ain't very quiet either, Maynard.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Dynomax Ultra-Flow SS?"
1968 Nova SS is about to end its Life Seagroves Hotrodders' Lounge 45 08-11-2007 09:18 AM
Poor mans flow bench hotmetal800 Engine 5 12-18-2004 01:13 PM
wet vs dry carb flow ratings Litdave Engine 10 09-08-2004 06:15 AM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
Stock eliminator 78 monte Engine 5 01-02-2003 05:10 AM
