Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Dynosim help and Engine Build Review
Old 09-07-2012, 03:38 PM
vinniekq2's Avatar
vinniekq2 vinniekq2 is offline
I use rocker shafts on my 434. You should consider that too for extended time at 7,000 rpm. use a rev limiter obviously. Not sure what those heads flow but you should still make over 600 hp from 6,000 rpms.
need head flow numbers at valve lift to get a better idea of HP
