Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Dynosim help and Engine Build Review
Old 09-09-2012, 05:21 PM
vinniekq2's Avatar
vinniekq2 vinniekq2 is online now
Rev kit can be used with ant camshaft.talk to your cam manufacturer about the springs you have and the new rocker arm ratio.The rocker shaft is good for sustained high rpms with w/e springs you need to use,,,
