-   -   Dynosim needed today (http://www.hotrodders.com/forum/dynosim-needed-today-191798.html)
blazaboy86 02-01-2011 06:26 AM
Hey guys, i'm in iraq about to start ordering parts for my 383 :D . Scat 9000 crank,5140 rods(5.7),forged -5cc dishes. Dart pro 1 platinum 215cc heads(2.05/1.60) with an edelbrock air gap rpm intake that i already own. (do i need single plane instead? :confused: ) It's gonna be a solid lift cam(290AS-14) with 1.6 roller rockers and a 750dp HP holley. 1 5/8 headers(shorties). I need to find out what kinda power i'm lookin at vs how much i want. Lookin for over 500 at the crank w/out nitrous :mwink: . I already have a 150 top shot NOS kit if that helps any. It's goin in my blazer but i don't care at all about driveability cause i know there are sacrafices when going for streetable high horsepower in these wonderful SBC's vs the new LSX engines. I'm 24 now but i still prefer old muscle for some reason, maybe cause that's just what i was raised around. Live Long GEN I SBC!!!!!!!
cowgirlup2 02-02-2011 03:32 PM
hey
:confused: im not sure
cobalt327 02-02-2011 03:35 PM
This is what you'll need to get an 'accurate' estimation:
Originally Posted by techinspector1
DYNOSIM REQUIRED DATA....
Bore
Stroke
Rod Length
Cylinder head flow, intake and exhaust 0.100" through 0.700" or whatever the mfg gives for range
Intake valve diameter
Exhaust valve diameter
Static compression ratio
CFM, type of induction (2-bbl, 4-bbl, TBI, TPI)
Intake manifold type, mfg (single 4-bbl, two 4-bbl, one 2-bbl, three 2-bbl, individual runner Weber, mechanical fuel injection, low-rise, high-rise, tunnel ram, dual-plane, single-plane, part no. if you have it.
Exhaust system (be specific, primary tube size if long-tube headers)
I have quite a library of CompCams (give me part number, not grind number) in my files, but if you are using another mfg, I'll need type (flat, roller, solid, hyd.), intake valve lift, exhaust valve lift and the following timing info and at what tappet lift the info is valid...(0.006", 0.050") I can calculate from 0.020" if I'm given enough information, but again, that takes my time.
Intake opens ______BTDC
Intake closes ______ABDC
Exhaust opens______BBDC
Exhaust closes______ATDC
Greg T 02-02-2011 04:16 PM
Dude, ya need to lost those headers. Shorties are rarely any better than stock manifolds.
blazaboy86 02-03-2011 12:50 PM
bore 4.030
stroke 3.75
10.5:1 Cr
Dart pro1 215 64cc 2.05/1.60
.200-152
.300-193
.400-239
.500-273
.600-289
.700-293
RPM Air gap intake
Holley Avenger 870cfm vac sec carburetor
1 5/8 shorty headers
After advice from my dad i'm more than likely gonna go with this cam.12-773-8[10] IVO-23deg IVC-53 EVO-64 EVO-16
