Dynosim needed today - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-01-2011, 06:26 AM
blazaboy86's Avatar
Hey guys, i'm in iraq about to start ordering parts for my 383 . Scat 9000 crank,5140 rods(5.7),forged -5cc dishes. Dart pro 1 platinum 215cc heads(2.05/1.60) with an edelbrock air gap rpm intake that i already own. (do i need single plane instead? ) It's gonna be a solid lift cam(290AS-14) with 1.6 roller rockers and a 750dp HP holley. 1 5/8 headers(shorties). I need to find out what kinda power i'm lookin at vs how much i want. Lookin for over 500 at the crank w/out nitrous . I already have a 150 top shot NOS kit if that helps any. It's goin in my blazer but i don't care at all about driveability cause i know there are sacrafices when going for streetable high horsepower in these wonderful SBC's vs the new LSX engines. I'm 24 now but i still prefer old muscle for some reason, maybe cause that's just what i was raised around. Live Long GEN I SBC!!!!!!!
Old 02-02-2011, 03:32 PM
cowgirlup2's Avatar
New Member
hey
im not sure
Old 02-02-2011, 03:35 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
This is what you'll need to get an 'accurate' estimation:
Originally Posted by techinspector1
DYNOSIM REQUIRED DATA....
Bore
Stroke
Rod Length
Cylinder head flow, intake and exhaust 0.100" through 0.700" or whatever the mfg gives for range
Intake valve diameter
Exhaust valve diameter
Static compression ratio
CFM, type of induction (2-bbl, 4-bbl, TBI, TPI)
Intake manifold type, mfg (single 4-bbl, two 4-bbl, one 2-bbl, three 2-bbl, individual runner Weber, mechanical fuel injection, low-rise, high-rise, tunnel ram, dual-plane, single-plane, part no. if you have it.
Exhaust system (be specific, primary tube size if long-tube headers)
I have quite a library of CompCams (give me part number, not grind number) in my files, but if you are using another mfg, I'll need type (flat, roller, solid, hyd.), intake valve lift, exhaust valve lift and the following timing info and at what tappet lift the info is valid...(0.006", 0.050") I can calculate from 0.020" if I'm given enough information, but again, that takes my time.
Intake opens ______BTDC
Intake closes ______ABDC
Exhaust opens______BBDC
Exhaust closes______ATDC
Old 02-02-2011, 04:16 PM
Greg T's Avatar
www.krusinklassics.net
Dude, ya need to lost those headers. Shorties are rarely any better than stock manifolds.
Old 02-03-2011, 12:50 PM
blazaboy86's Avatar
bore 4.030
stroke 3.75
10.5:1 Cr
Dart pro1 215 64cc 2.05/1.60
.200-152
.300-193
.400-239
.500-273
.600-289
.700-293
RPM Air gap intake
Holley Avenger 870cfm vac sec carburetor
1 5/8 shorty headers
After advice from my dad i'm more than likely gonna go with this cam.12-773-8[10] IVO-23deg IVC-53 EVO-64 EVO-16
Dynosim BMEP's seem out of line... nofearengineer Hotrodding Basics 3 12-18-2010 06:03 PM
DynoSim 455 Pontiac techinspector1 Engine 23 04-01-2009 05:20 PM
need a quick dynosim cam comparison automods Engine 18 01-26-2009 03:41 PM
Playing with DynoSim Pro Tools techinspector1 Engine 27 10-04-2008 07:31 AM
Sad day today Capt. Camaro Hotrodders' Lounge 10 09-13-2003 03:07 PM
