Hotrodders Bulletin Board
#16
re: DZ 302 Vs 327 ????
TRW used to make spacers to put a small crank in a large block.
Large journal forged 327 cranks reportedly only came in trucks and Corvettes. But, I've heard of all kinds of weird stuff coming off the assembly line. |
#17
Some friend he was. ![]() |
#18
"large" Journal 327 crank
Hello every one, I happen to be a old time drag racer from way back and i do happen to no that if im right the 307 also carrys a 327 crank in it in 1970 and it is also a "large" Journal crank if that helps you. and if im right i happen to have a few of them if needed let me no. Thanks Again " PaPaBigBlock
#19
Another one of those amazing retro threads. This thread was hatched 5 years ago, then again 3 years ago. Look at the dates before you post.
#20
I've seen more 302 cranks in my short life time than large journal forged 327 cranks .
I agree though, 327 all day long but then again with the stuff that's out there, a properly prepped 350 short block will turn the rpms too for less money than the SJ stuff. I think if you google 'eagle chevy 302 crank' that a speedshop out of FL sells a 3" stroke crank- 4340 for $600, same for a 3.25" crank. 307 is a 3.25" stroke but I'm sure they are all cast. And I have no problems with cast but once you put the money into a relatively high rpm build then you might as well fork over the dough for a better crank, in my opinion anyway. But as we all know a cast crank, late model PM rods w/ ARP bolts and hyper or forged pistons will take 6,500 any day and higher (but I wouldn't feel too safe past 7,000). This story could be pure BS because I haven't seen it, just the tach recall, but my friend runs a 1/8th mile car with a GM 'Delux' 330 hp crate motor. He took off the vortec and hydralic cam and put on Dart Iron Eagle 220 heads w/ 49cc chambers and a huge solid lifter cam. The tach recall showed 8,100rpm on a stock short block. |
#21
Man don't I feel like the idiot dv? Just saw your post after I posted...
#22
Ah man, no need to feel like that. No harm no foul. Sometimes I wish those that post would pay attention to the dates is all. But I did see he was a 1st time poster so it`s over looked. Believe me man, your not the only one who wishes they could turn back the clock. If I could only turn it back to 2000 and know then what I know now. But it wouldn`t be for automotive reasons.
#23
This may be an Old Threaded But it's a Good one . Yes that 307 Crankshaft is a L/J 3.250" Cast Crank Just Like the STD 1968-69 327's Used . I think if you Built a 327 Part for Part Like a DZ-302 . You will have more H.P and Torque . |
#25
You can use special bearings to install the small journal crank in the large journal block.
#26
\ So let me ask, I just bought a 1969 camaro 4sp with a 307. are you saying that my motor has a large journal? god i hope so because i also have a 327 block with numbers matching 2.02 heads from a 69 DZ 302. Will that crank i have work in my 327 to make my dream engine 302? Paul |
#27
307 and large-journal 327 use the same crank. If you have a large-journal 327 block, the 307 crank will work in it, using 327 pistons, but you won't have a 302, just a 327 with a cast crank. Which is not at all a bad thing, it's just not your dream motor. |
#28
3070crank vs ?
hey thanks alot. i did not know that the crank would work. I have recieved alot of informaition to make my motor. I might be going another route that would encompass the crank with aftermarket heads with a complete roller set up.
Thank you Paul |
#30
