E-85 ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-30-2008, 04:24 PM
Marcel
Last journal entry: Choo-choo town
E-85 ?
What do you have to do to run e-85 fuel in and older engine (V8 chevy) and how does it effect performance? thanks
Old 04-30-2008, 04:34 PM
Jmark's Avatar
This has been discussed quite a bit and always gets heated. If you do a "search" for e-85 on this site, you will find many many threads on the pros and cons.
Old 04-30-2008, 04:46 PM
Marcel
E-85 fuel
Jmark, I typed in e-85 fuel and got no matches, where or what should I search under> thanks
Old 04-30-2008, 05:32 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
I typed in E-85 on the search function on this site and it pulled up a whole bunch of threads . Check it out http://www.hotrodders.com/forum/sear...archid=1753617
Old 05-01-2008, 08:21 PM
Infomaniac's Avatar
Twin Turbo Drag Boat
Last journal entry: Random In Progress Shots
Yea lots of articles. It's a great thing for high compression or boosted engines.
For the most part E-85 is extremely inconistant on the blend. If you notice, the mixture percent listed at the pump has a wide range. So tuning might be an issue.
If it's an engine with a good engine management system it's a lot easier.
I intend to run it in my boat and also the blown street machine soon. I will just keep some straight ethanol in the shop so I can tweak the mixture as needed.
85 Chevy s-10: won't start, suspect elec probs now joe99 Electrical 7 12-15-2010 11:58 AM
85 fuel switch wiring thunder customs Electrical 3 03-14-2007 07:20 PM
Box from a 1995 chevy on an 85 silverado? 85silverado Body - Exterior 0 04-13-2006 11:20 AM
E 85 and 12:1 comp johns11 Engine 1 05-01-2003 03:49 AM
85 chevy 305 heads on an 89 TBI chevy 350? jazzguitar Engine 4 11-03-2002 04:11 AM
