E-Brake - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-14-2002, 12:42 PM
Post E-Brake
Any sugestions for a good e-brake for my t-bucket. Have a Chev. S10 rearend. Any help is much welcomed. Thanks, reclusej
Old 11-14-2002, 02:51 PM
johnnymopar's Avatar
Love your nails! You must be a Libra
Talking
you could check out Lokar or go to a wrecker's and get a e-brake from a console.
JB
"Well done is better than well said." - Benjamin Franklin (1706-1790)
Old 11-15-2002, 03:41 PM
F-1Rodder's Avatar
Post
I am sure you will see just about everything in use for that. Lokar is the simple, but not the cheapest solution. They have all the adjustable cables in lengths you need, I believe it is all stainless and is designed with variable application in mind.
I personally ended up pulling a center pull unit from VW and used a cable out of a Camaro. Most of the car cables you will find are much too long for what you need.
