E-brake position/auto trans66 - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-21-2005, 02:01 PM
I've looked at a few 66 chevy trucks with automatics installed replacing original 3-speed; seems everyone opts to remove the parking brake brackets/cables. I haven't yet located a crossmember for the 350 that's in my truck (it's sitting on the old original crossmember which is several inches forward of the trans mount on the 350). I may switch to a 700R4, but I definitely don't want to eliminate the E-brake mechanism. Suggestions?
Note: I believe my frame is from an older truck because the frame no. doesn't match the VIN; I had to relocate radiator mounts and the rearend indicates a '64 but no one has been able to solve this mystery.
Last edited by stepsidebingo; 10-21-2005 at 08:41 PM. Reason: non-specific vehicle info
Ford Galaxie Disc Brake Conversion CrashFarmer2 Suspension - Brakes - Steering 5 04-10-2010 04:52 PM
brake question Ratoflic Suspension - Brakes - Steering 1 09-29-2005 10:32 AM
brake lights stay on.... jmtw Electrical 6 03-06-2005 07:48 AM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 06:17 AM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
