e-brake setup w 4 wheel disks - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-12-2008, 10:41 PM
So I have a custom 67 camaro that has been upgraded to 4 wheel wilwood disks. So how does one rig up an e-break? Is there something like a line lock out there that is designed for e-breaking??
Thanks James
Old 07-12-2008, 10:57 PM
weirdbeard's Avatar
1976 Ranchero GT
Last journal entry: Almost time for the first drive!
Most all emergency brakes are not hydraulic . Thats the point I guess in case of hydraulic failure.
The ones you see on most stock four wheel disc cars use a rear caliper that uses a cable to twist the piston out for contact on the disc. I am surprised that Willwood does not have this worked out...
Old 07-13-2008, 02:58 AM
techinspector1's Avatar
Wiki Edits: 326
http://www.tperformance.com/street_r...ncy_brake_kit/
Old 07-13-2008, 08:26 AM
It probably would have been cheaper to get the caliper's with the e-brake on it.
Old 07-13-2008, 08:57 AM
302 Z28's Avatar
The Wilwood 4 disc setup on my 34 has a small brake drum built into the rear discs. This however is not an "emergency" brake so much as it is a "parking" brake. Applying it while moving imparts little stopping effort.
An emergency brake that uses the same hydraulic system as the vehicle brake system is NOT an emergency brake. A hydraulic failure will disable both the vehicles brake system and the emergency brake.
Vince
Old 07-13-2008, 09:25 AM
Irelands child's Avatar
Total Performance sells 2 different kinds of parking (emergency??) brake - a hydraulic and a mechanical pinion mounted version. In my state, NY, the hydraulic isn't legal - a discussion that the owner of TP and I had several times. They now offer the mech version. Another company in CO offer a real nice pinion mounted version (http://www.tsmmfg.com/) which I originally had on my car until I switched to the Wilwoods - though the earlier version then Vince's Ford Expedition derived assembly - mine uses a secondary but mechanical spot caliper. One drawback to this assembly - most 15" wheels will NOT fit over that little caliper, a $900 screwup for me.
This one is mine:
Irelands child
Old 07-13-2008, 10:16 AM
The guy that built the car had to have everything match. And the Wilwood 4 disk set up uses (I think) smaller pistons, slightly different machining, and brushed alum on the back, and polished alum on the front. So he bought 2 sets of front disks, and then custom machined them to make them work on the rears. Thus I have no e-break function on the rears, and probably the only car in existence with polished wilwood disks front and rear.....
Thanks for the pic Ireland, but what is the system your using? Unless I missed something I don't think you told me...
Thanks for the tips guys I will look into Total Performance...
Any other ideas, in case i can't make that work??
james
Old 07-13-2008, 10:45 AM
james
TSM is, IMHO, better "stuff" http://www.tsmmfg.com/
Irelands child
Old 07-13-2008, 10:48 AM
Is that the system you are using? It looks good, and would probably work for me.....
Old 07-13-2008, 10:49 AM
I don't see anything on that site that looks like a parking break??
Old 07-13-2008, 10:56 AM
T-bucket23's Avatar
Wiki Edits: 26
I have the TP one and it is the only item I purchased from them that was dissapointing. That other site that was posted sells the same product by looking at the pictures.
Old 01-22-2012, 04:47 AM
e-brake
i am just putting togather a hyd e-brake with a seperate hyd rear piston/hande brake using an added 4piston caliper and a cutom made axle bracket for the edded caliper.
Old 01-22-2012, 05:43 AM
handbrake
here is the handbrake made by Wilwood/ASDmotorsports but there are others that will wratchet lock.
'39 ford steering column and wheel jim williams Suspension - Brakes - Steering 5 07-01-2010 09:38 PM
master cylinder interchange runn141 Suspension - Brakes - Steering 7 05-03-2009 05:15 AM
SS brake line question-as promised techron Suspension - Brakes - Steering 3 12-26-2007 06:58 PM
Steering wheel decision help guba_unus Suspension - Brakes - Steering 2 02-12-2006 10:21 AM
front disc brake wheel cylinder??--bleeders Tom34ford Suspension - Brakes - Steering 2 06-03-2002 04:02 PM
