E-Coil vs. Oil Filled Coil - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-28-2008, 08:13 PM
acr acr is offline
Is anybody using an aftermarket E-coil & is it better/worse for a mildly built street motor than the old style oil filled? Any brand preference?
Old 03-02-2008, 02:54 PM
T-bucket23's Avatar
Wiki Edits: 26
I like MSD coils, I think there are pluses and minuses to both types of coils.
Personal preference is the old style oil filled
Old 03-03-2008, 12:36 PM
streetrodderbn's Avatar
Certifiable Streetrodder
I have had good luck with the M.S.D. and Pertronix coils. I have had good results with the e coil and the oil filled coils. As a good rule of thumb, always match the coil and distributor if possible as per the manufacturer's recommendation, you will have a lot less hassles to diagnose a problem or facilitate a return with a defective unit or sub unit. The manufacturer will always fault another manufacturers part as the problem until you change it to their recommended part! I rarely see coil failures at all within the 1st 30,000 mi.!
Ignition system info................ poncho62 Electrical 18 10-11-2008 10:10 PM
How Does This Stuff Work? docvette Electrical 3 06-18-2006 03:00 AM
gas prices and hotrodding ! engineman302 Hotrodders' Lounge 87 04-24-2006 08:27 AM
Oil Temperature and oil types (long) TurboS10 Engine 36 03-01-2005 01:51 PM
