E-Crate Engine, re-power, '87 GMC 1/2 tn P/U - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-30-2011, 10:58 AM
Interested in finding an experienced shop to re-power my '87 GMC 1/2 tn pick-up with one of the new 6.2L E-Crate engines from Chevy. The shop needs to have performed similar swaps previously and be familiar with the SMOG implications. I'm located in Solano County, and hope to find a shop between Sacramento and the Bay Area.
Craig
Old 09-30-2011, 12:15 PM
ogre's Avatar
the 'Duracell Project'
jcraig
those e-rod crate motors are the greatest thing for the hotrodding industry for the non-motor building crowd. i'm thinking that they are gm's response to the popularity of the ramjet 350 and 502 crate motors. i have the ramjet 350 in my truk. it came with everything needed to transplant into my 58; pan, valve covers, complete wire harness, plugs, oil filter and even an air cleaner. i only had to add motor mounts, a starter, front end accessories and power to it.
any shop that can swap an ls type motor should be able to this. due to the newness of the e-rod motor i think you would find it difficult to find any shop with experience on this particular motor. the e-rod motors are stand alone motors that is; it comes with it's own computer and will run in anything, even a motor stand.
as for smog, they come with cats and o2 sensors. gm worked with sema to design a 50 state smog compliant motor. from summit:
GM Performance has worked closely with the California Air Resources Board (CARB) to secure emissions approval for these high-horsepower, high performance engines. These GM Performance LS3 6.2L E-Rod crate engines are the first crate engines of their kind to be certified 50-state emissions compliant. With their stunning combination of horsepower and efficiency, these GM Performance LS3 E-Rod crate engines are perfect for the race track or just cruising around town in your street rod or musclecar.
Old 10-01-2011, 03:02 PM
327NUT's Avatar
Did you really say "stunning" or was that just a bit of plagiarism from GM's web site?
Old 10-02-2011, 10:38 AM
ogre's Avatar
geez, the grammar police are invading?
correctly noted ''from summit:''
GM 350/290 HP crate engine ??? rocknmore Engine 8 03-14-2011 01:13 PM
Ford 351W crate motor (385hp ver.) advice- low on power? saki302 Engine 9 04-21-2010 04:14 AM
350 Crate Engine: Loud humming sound after engine warms up sofa1515 Engine 2 01-11-2010 07:48 PM
GM zz4 Crate Engine Betty Transmission - Rearend 3 05-16-2008 09:41 PM
350 crate engine Seon Engine 2 11-13-2002 06:58 PM
