Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - E-curve distributor???
Old 01-16-2013, 08:34 PM
396chevelle's Avatar
396chevelle 396chevelle is offline
Ok, thanks for the input guys! I went ahead and ordered one, so hopefully it will be here tomorrow! SPINN, I'll look into that screw cap conversion! Thanks for the heads up! GREG T, I called MSD and Comp Cams to make sure I was good with the gear that comes on it and they both said I was good with the flat tappet, but if I run the roller I would need to change it! Glad all has been good, but I just wanted to let you know cause I hate for the cam gear to wear out and you get metal shavings in that motor! Ireland, thanks for the gear compatibility. Cast iron comes stock on the e-curve. Thanks everybody! Sure hope it don't crap out! Cause it was $$$$$!!!
The Following User Says Thank You to 396chevelle For This Useful Post:
Greg T (01-16-2013)
