Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - E-curve distributor???
Old 01-16-2013, 09:26 PM
Greg T's Avatar
Greg T Greg T is offline
www.krusinklassics.net
Originally Posted by 396chevelle View Post
Ok, thanks for the input guys! I went ahead and ordered one, so hopefully it will be here tomorrow! SPINN, I'll look into that screw cap conversion! Thanks for the heads up! GREG T, I called MSD and Comp Cams to make sure I was good with the gear that comes on it and they both said I was good with the flat tappet, but if I run the roller I would need to change it! Glad all has been good, but I just wanted to let you know cause I hate for the cam gear to wear out and you get metal shavings in that motor! Ireland, thanks for the gear compatibility. Cast iron comes stock on the e-curve. Thanks everybody! Sure hope it don't crap out! Cause it was $$$$$!!!
Thanx for the heads-up! I'll check that out and see what I need. I read the directions in full and nothing was said about the gear at all. Since rollers are the norm these days I would have thought they'd be compatible. Thanx again!
