I am using a Derale adjustable controller on a two speed single fan set up. The Summit part number is DER-16749.
http://www.jegs.com/p/Flex-a-lite/751522/10002/-1 ![]() You simply turn the screw to adjust the activation temperature. Once it's adjusted, forget it. You can also wire in a backup toggle switch if you feel you need it. This particular unit sells for $30, but I've seen them under $20. |
That looks awfully similar to the one at Advance- it has the radiator probe. I've seen a couple other varieties that have a sending unit that screws into the head.
That's one of the ones I've been looking at. How long have you been running that one? How many miles/years, etc? Any problems whatsoever? I really don't need, nor want, to spend a whole lot of $$ on it, but knowing that you get what you pay for a lot of times, I want to get something that I can set and forget about, and that will last. Do it once, and do it right. |
![]() YMMV but IMO overkill on the fan relay is a good idea, right now I'm using a 250 amp golf cart relay on a manual switch with no further problems, I'm planning on wiring in an OEM temp switch when cash flow improves. |
| Recent General Rodding Tech posts with photos |
| building a fan shroud - need help | 32Tudor | Hotrodding Basics | 30 | 07-03-2008 09:01 PM |
| Correct size & type of radiator fan & clutch? | Steve S | Engine | 3 | 12-04-2006 10:29 AM |
| Electric cooling fan | Z-Money Pit | Engine | 1 | 08-29-2006 08:27 PM |
| Need advice on a good electric fan set up. | Streetmaster | Engine | 13 | 01-07-2006 02:37 PM |
| ? about an electric fan for PU. | Streetmaster | Engine | 8 | 08-20-2005 10:14 PM |
