-   -   E force pulleys for more (http://www.hotrodders.com/forum/e-force-pulleys-more-223877.html)
spinn 09-10-2012 10:08 PM
I heard magnuson makes press on pullies for the carburetor Edelbrock E force superchargers. After a search or two my efforts are fruitless. They seem to be for other systems. Would pulling the driven off damage the shaft? Does anybody make a 4 bolt -on style conversion like the other e force kits?
My 305 is at 5+ psi at 5200 rpm. Looking for a 3.35" to get about 8 psi by that rpm. Then it can take advantage of the MSD BTB retard. The boost ramps up with rpm mildly and the sneeze valve is good protection not on the other roots blowers. It is silent too which is likeable.
Very impressive for a 305 with a performer cam. Most impressive.
spinn 09-13-2012 02:39 PM
2 Attachment(s)
Look what came in the mail this morning. My BS 3" pulley for the e force. $39.99 free shipping.
E force pullies at 6000rpm make an amount of boost based on driven/snout diameter. Estimated at 2 psi less for 5200rpm. When used with the stock drive/crank pulley.
- 3.25" = 7.5~9.5psi
- 3.00" = 9~11psi
- 2.75" = 11~13psi
This was so easy to , pull, and press. The results are immediate. It blows my mind. Why did I waste all that time building small block combos. This smokes any normal build, and have no detonation using the MSD BTR. It actually works and retards dialed to 26 total at 5200rpm. 91 octane and 9+ psi, the power is coming on harder than I ever thought a 305 could put out. The performer cam with a LSA of 112 is perfect, and works with the 906 1.94/1.50 60cc vortec heads like a charm. No plans to rev it higher and change cams.The heavy 85 C10 feels like a toy with the Dynamic built 3000 stall and 3.73 gears.
Every 2.5 psi is supposed to be 40-50 hp. So if My performer cam vortec 305 made 250hp NA, and e forced at 5psi made 350hp. Now it is making an estimated 450hp! Never has my 350s or 440s been this streetable at anything close to that power level.
Thanks Edelbrock, I am $2000 happy. This 305 hauls. I can twist the trucks 85 mph speedometer completely around in less than 10 seconds .
Should I try the 2.75" pulley? $40 bucks for another 50 hp. The OE block is good for 450hp or so.
spinn 09-13-2012 10:10 PM
Any water injection system you want recommend? Your ideas about increasing boost were on target. If it is not too much , I will check it out.
My power estimates are just guesses. It is moving forward pretty good.
Different combos are not a waste really. This is just a short cut. Is there any down side? If it maintains its reliability and driveability what is going to go wrong? Rings? It has about 3,000+ miles, driven after the blower. So far , so good.
spinn 09-13-2012 10:53 PM
When I checked the mounting bracket with a temp gun, it was the same as the inner fender. It had to be flipped upside- down because if you open the hood after raining, it drips down.
V305 09-13-2012 11:29 PM
That supercharger looks nice. The MSD Box its to close to the engine, but if temp its ok you can leave it there. MSD recommends NOT to install the box facing down because that way moisture will not come out (experience). That mounting plate looks cool btw.
spinn 09-14-2012 09:40 AM
Detonation detection, what would you do? That is a great idea and a concern of mine. You think a knock sensor placed in the block drain plug, or near the intake track, would be sensative spot. It could be wired to a LED in the cabin on a voltage sensing circuit.
The box cannot be mounted underneath ? It doesnt get a shower of water when I pop the hood, but a few drops. So it is better the other way? Originally it was going to be placed in cabin. underneath the dashboard behind the glovebox and heat vent duct. Unfortuneately it makes a buzzing at operation and that was crossed off as a location. I could fashion a lexan cover from my nephews old rc car body. Might look strange.
Strange- These water injection / HHO systems I glanced. A water bottle with heet and a sponge to the vacuum port, is going to work?
