E-sreet heads - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-21-2012, 12:52 PM
vinniekq2's Avatar
that small cam and heads should put you in the 500 hp range. Dont use 660 center squirters on the street.Do you have any actual flow numbers for the heads? I would use a 750 double pumper.The car could run 11s.If you use 2 600 carbs and progressive linkage It should get reasonable mileage compared to the holley 750X and still be close to the same speed in the 1/4 if you ever explore that?It should at least run low 12s
  #17 (permalink)
Old 10-21-2012, 01:16 PM
Yeah ' I was running the 660's on the street -had it running good,made more than the eddies ,but one of the throttle shafts wanted to leak,so I went to the endurashine-looks better with the open car.I've been running both carbs at once on the 454 & it went good .Better on gas than the 660's. Might try the strip sometime,too easy to get reported street racing.Hope you're right about the HP thanks..................Gus No, I don't have any flow numbers,they're just E-street heads the way they came
  #18 (permalink)
Old 10-21-2012, 01:31 PM
vinniekq2's Avatar
this is what they advertise
with flat gasket seat.
Flow Numbers as tested by Edelbrock's SuperFlo SF-1020 flow bench @ 28" H2O
#5073, #5089
Valve Lift .100" .200" .300" .400" .500" .600" .700"
Intake 74 143 207 250 284 309 -
Exhaust 71 128 153 178 200 218 -
So,they have the potential for over 500 hp if the numbers are correct.I believe 500 ish to be close. I guess you use the 2 carbs for show?
  #19 (permalink)
Old 10-21-2012, 01:58 PM
Yeah, THe Hi-ram & endurashine carbs with K&N velocity stacks.I know there's better ways to make power ,But it's a fun ride anyway
Oppinions EQ lightening heads and EQ vortec heads eatonde Engine 16 02-18-2013 11:00 PM
305 heads or 350 heads on sbc 355 ryan v Engine 7 09-20-2012 10:21 AM
Any from nc done a sreet legal s10 v8 swap? gdav Engine 6 06-14-2008 08:51 PM
SBC cylinder head bolts .. cast iron heads Vs Alum. heads terror385 Engine 3 08-04-2006 08:34 PM
Vortec heads or 1971 487x LT1 heads? speedfrk3 Engine 2 10-07-2002 04:12 PM
