E-sreet heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-20-2012, 01:15 PM
E-sreet heads
I have a 427 bbc with balanced forged crank scat rods & forged wiseco 9.5 pistons.Will 110 cc e-street heads work with a SLRcam 532-522 lift & 282-292 duration.The valves are .219-.188.Will I have enough compression?.........Gus
Old 10-20-2012, 05:23 PM
hcompton's Avatar
Old & Furious
You can use this to find the dcr of you engine with that cam then find out from others what a good dcr is for your engine head combo.
United Engine & Machine Co. Incorporated
Not sure what a good dcr for your app would be. Most ppl say 8.5:1. Small block chevy can get pretty high compression ration with big cam and alum. Heads.
Hope this helps.
Old 10-20-2012, 09:43 PM
E-Street Heads
Thanks for the comeback guys.I have a little more info- the dome volume is 21 cc The pistons are wiseco #5046H6 .The deck has been milled to clean it up, But i'm not sure of the height. The cam is a SLR grind#300DP Hyd-110" The specs are Lift 532. 522 , duration 282,292 intake open 35 exh 80 . close intake 67 exhaust 32. On the next page it shows exh opens@53 BBDC intake opens@8 BTDC. Exh closes@5 ATDC. Intake closes @ 40 ABDC . Hope that helps & Thanks Guys......................Gus P.S Those are @.050 tappet rise
Old 10-21-2012, 12:04 AM
E-street heads
Sounds good, The cam is a Steve Long Racing Cam . Don't know of a web site, but it's out of california. Any idea what kind of power it'll make ? I'm using a Weiand Hi-ram w/ two 600 eddies .Thanks again.............Gus
Old 10-21-2012, 02:14 AM
I've got two 660 centre squirters w/50cc pumps & 35 cc extended squirters I could use. Also have another cam ,a Comp extreme marine part # 11-236-4 Grind #CBXM 270H-12, it's already in this motor. Here is the specs as on the sheet. Gross valve lift int..544,exh.547 duration@.006 tappet lift int.270,exh.286 valve timing@.006 int. open@25 BTDC close@65 ABDC exh.open@77 BBDC close@29 ATDC. At 110.0 int. centerline. duration@.050 int.226 exh.236. Lobe lift int..3200 exh..3220 . Lobe separation 112. Should I leave this one in or the other one for now . If I go the solid route what would you suggest ? Thanks for all the info.......Gus
Old 10-21-2012, 05:14 AM
I'll be running it in a '23 T bucket-2-spd Powerglide ,narrowed 9", 355s,Eaton locker, wide mickeys on the back. Iwas running it in a V-drive boat,hence marine cam. The bucket has a 454,but I thnk the 427 will be better,it only has about 10 hrs since the overhaul.I had just put the aluminum heads on the 454 & cam etc ,but the rotating assembly is stock.
Old 10-21-2012, 11:26 AM
yeah it's a lot of fun,I forgot to mention it has a billet 3000 stall & transbrake,just had the tranny done supposed to be good for 750 hp..Car weighs 2200 lbs.Maybe I'll leave the Comp. in I'll have both motors on the engine stands,so either way it's not a lot of work.Thanks again for all the info-appreciate it..............Gus
Old 10-21-2012, 01:35 PM
I'm a retired truck driver so I don't mind the manual shift.
Old 10-21-2012, 01:52 PM
vinniekq2's Avatar
that small cam and heads should put you in the 500 hp range. Dont use 660 center squirters on the street.Do you have any actual flow numbers for the heads? I would use a 750 double pumper.The car could run 11s.If you use 2 600 carbs and progressive linkage It should get reasonable mileage compared to the holley 750X and still be close to the same speed in the 1/4 if you ever explore that?It should at least run low 12s
Old 10-21-2012, 02:16 PM
Yeah ' I was running the 660's on the street -had it running good,made more than the eddies ,but one of the throttle shafts wanted to leak,so I went to the endurashine-looks better with the open car.I've been running both carbs at once on the 454 & it went good .Better on gas than the 660's. Might try the strip sometime,too easy to get reported street racing.Hope you're right about the HP thanks..................Gus No, I don't have any flow numbers,they're just E-street heads the way they came
Old 10-21-2012, 02:31 PM
vinniekq2's Avatar
this is what they advertise
with flat gasket seat.
Flow Numbers as tested by Edelbrock's SuperFlo SF-1020 flow bench @ 28" H2O
#5073, #5089
Valve Lift .100" .200" .300" .400" .500" .600" .700"
Intake 74 143 207 250 284 309 -
Exhaust 71 128 153 178 200 218 -
So,they have the potential for over 500 hp if the numbers are correct.I believe 500 ish to be close. I guess you use the 2 carbs for show?
Old 10-21-2012, 02:58 PM
Yeah, THe Hi-ram & endurashine carbs with K&N velocity stacks.I know there's better ways to make power ,But it's a fun ride anyway
Oppinions EQ lightening heads and EQ vortec heads eatonde Engine 16 02-19-2013 12:00 AM
305 heads or 350 heads on sbc 355 ryan v Engine 5 09-20-2012 11:21 AM
Any from nc done a sreet legal s10 v8 swap? gdav Engine 6 06-14-2008 09:51 PM
SBC cylinder head bolts .. cast iron heads Vs Alum. heads terror385 Engine 3 08-04-2006 09:34 PM
Vortec heads or 1971 487x LT1 heads? speedfrk3 Engine 2 10-07-2002 05:12 PM
