E-Z harness/Chevy column - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-03-2008, 07:32 PM
I'm a long time muscle car guy from southern Illinois ,I currently own a 66 Mustang FB ,GT 350 clone,and a 63 1/2 galaxie with a429 cj,c6 and all the restomod goodies. My question is about my galaxie ,I am using a 97 chev van steering column and an aftermarket wiring harness by E-Z wiring out of Fla.
It came with all the plugs for ign,turn,horn etc,but not wiper circuts .Can anyone tell me which wires and plug on my column to use so I can use the wiper switch on the t/s stalk. also thanks for the welcome.
Old 12-31-2008, 12:49 PM
thewrongshop@yahoo.com
wiper wire
If you have an OHM meter just go by process of elimination , put the wiper SW on high and check what wire has the continuity, that should get you where
you want go.
Old 12-31-2008, 05:03 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
Wiper motor always has power to it with the key 'on'
the switch on the column most likely switches a relay or two or three for wiper operation.
Wiper harness may be a harness all to itself and the wiper power may be supplied by the ignition switch.
So---double check how everything works---I would be glad to show you, but my 79 chevy diagrams do not have column mounted switches for the wipers.
Loose Gm Tilt Steering Wheel Moves Up And Down fumplet Suspension - Brakes - Steering 10 05-13-2012 06:07 PM
Chevy AD truck steering column question mr52pickup Suspension - Brakes - Steering 1 10-24-2008 06:45 PM
neutral safety switch wiring ford column to 700R4 49willard Electrical 7 12-01-2007 05:27 PM
Steering Column Install Quarter Flash Suspension - Brakes - Steering 3 05-10-2007 11:36 AM
GM Column Wiring - Help Please Centerline Electrical 1 04-15-2005 05:29 PM
