E4OD transfer case bolt pattern ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-05-2006, 02:59 PM
Jared's Avatar
I have a 1996 460 engine and transmission ( E40D) I was wondering if any one on this board knows if the transmission will bolt to a np205 transfer case. It looks to have the right bolt pattern and I know this is the replacement for the c-6 that came with 205's so im thinking it should fit. any help is appreciated. thanks.
Old 12-05-2006, 04:24 PM
pmeisel's Avatar
Glad the Jeep is on the road
Last wiki edit: How to identify a Ford V8
I don't know for sure but I think you are right. When they went from the C6 to the E4OD the changes in the case machining were minimal, they didn;t change anything they didn't have to, so I don't think they changed that.
bolt pattern changing jniolon Body - Exterior 6 08-01-2005 01:02 PM
Turbo 400 leaks into transfer case latheman Transmission - Rearend 2 02-13-2004 06:09 PM
Epicyclical gears for 4x4 transfer case mpescatori Transmission - Rearend 2 02-09-2004 02:12 AM
NP 208 transfer case torque rating will it hold a 429? Jared Transmission - Rearend 4 12-09-2003 09:42 PM
Aluminum Transfer Case Bigdude_79 Engine 1 12-05-2002 08:38 PM
