Eagle 383 stroker - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-09-2008, 01:39 PM
75GMCman's Avatar
Eagle 383 stroker
I just bought a 383 stroker kit from eagle part # B13404E30 and I thought there would be main and rod bearing oil clearance spec's, but I was wrong! Can someone tell me what these spec's are?
Thanks Caleb.
Old 11-09-2008, 03:10 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
Caleb, you'll get many different answers to this question, but generally speaking, 0.0015" to 0.002" on the rods and 0.00175" to 0.0025" on the mains.
Old 11-09-2008, 03:30 PM
King of my Man-cave.
When you have that crank turned to fix the screwed-up journals, you can discuss the clearances with the machinist.
tom
Old 11-09-2008, 05:27 PM
racecar100's Avatar
I've seen too many Eagle Crank and rods torlrance is way out much as .002. So I went to Scat and never had any problems.
Old 11-09-2008, 06:59 PM
coldknock's Avatar
tom
To the original poster, Don't think Tom is just yankin' yer chain. He's serious and so am I. Take the crank to your shop and have it checked out. More of then than not Eagle cranks need it.
Don't use a stretch guage on the rod bolts either, if they're the I-beam rods.
Larry
Old 11-09-2008, 09:18 PM
Last wiki edit: Calculating tire size
Last journal entry: Changes...
Wiki Edits: 2
You can run up to .003" clearance on the mains and rods if thats what you end up with.
Old 11-09-2008, 09:22 PM
Crosley's Avatar
Wiki Edits: 1659
I've had Scat crank shafts way out too.
The one in my current 383 sbc was cut .010 on the mains and rod throws to straighten out the problems.
My machine guy says Eagle has fewer problems..... and some companies take the cranks and 'tune' them up before selling them at a marked up price
Old 11-10-2008, 06:55 AM
CNC Blocks Northeast
We stopped using Eagle cranks years ago they were so bad and Liberty Engine parts warehouse has seen a number of Cast 383 cranks break on the front and not buy the same customers they sell to either.
I have found Scats to be a better peice but we have gone to the Callies Comstar crank as those are top of the line and are dead nuts straight and journal size is right on from journal to journal.
I Think Tom can verify that!!
Old 11-10-2008, 08:12 AM
I find the Scat cast cranks are better than Eagle's cast and forged series. Scat's forged (4340) cranks seem to be quite good lately.
I agree with Carl, the Compstars are very good quality.
Eagle's forged are ok if you have them fixed in the beginning. I too have seen the cast Eagle 383 cranks break.
I will not sell and would not recommend the Eagle SIR I-Beam rods for any SBC application.
tom
Old 11-10-2008, 10:43 AM
75GMCman's Avatar
How are you guys making these cranks break ? (racing, dyno, race engines)?
Old 11-10-2008, 10:49 AM
I never use cast cranks in my builds!! But the sales rep from Liberty said they were mostly street and strip builds.
Old 11-10-2008, 12:16 PM
I don't it's entirely the owner's fault.
I have seen 2 break in a 4x4 truck.
tom
Old 11-12-2008, 09:04 AM
75GMCman's Avatar
Did they tell you what they were doing when it did break?
Caleb
Old 01-29-2009, 12:21 PM
383?
ive got a 93 z28 camaro. It has 110xxx on it right now and in the next year or two im planning on putin the 383 stroker kit in it. I want to do most of it by myself. Can anyone tel me what all i need to do to get it ready for the 383. I know all the parts you need for it. I know u have to bore out your block .0030. What all needs to be done?
Old 01-29-2009, 12:26 PM
Senior Curmudgeon
Wiki Edits: 326
Check 3 places. Small end of rod to underside of piston crown, rod to cam lobe and rod to block lip at the oil pan.
383 stroker v.s. 383 chrysler ...the end mcharger440 Engine 58 12-07-2012 08:16 AM
383 stroker are Dart Iron eagle heads OK truckster69 Engine 23 07-31-2011 02:17 PM
383 Stroker Question thebellman Engine 3 02-01-2007 02:56 PM
383 with 6in eagle h-beams anyone? 383mudlust Engine 21 01-25-2007 10:12 AM
Dart Iron Eagle Heads For a 383 stroker truckster69 Engine 3 01-05-2005 02:10 PM
