Eagle Crank Thrust Failure 383 - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-15-2010, 07:46 PM
Has anyone had experience with poorly ground Eagle Brand Crankshaft Thrust surfaces causing bearing failure on recent rebuilds? my engine has 6000 miles on it and was burning oil real bad. after removal, it was sent to the engine rebuilder, who blamed it on Converter ballooning. the problem is that the bearings were fine on the old motor. Even though he said he never had a problem with eagle cranks before, He made sure i was aware of Eagle not standing behind their Cranks. Any info on this would be Greatly appreciated. Thanks, John
Old 04-15-2010, 10:33 PM
BOBCRMAN@aol.com's Avatar
Thrust bearing problems are usually caused by non-crank issues. MOST of the manufacturers of Hot Rod equipment do not warranty parts after installation and use.
Old 04-16-2010, 06:20 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Are you thinking the TC hasn't ballooned? Have you had a chance to actually see/measure the TC yet?
Because if the converter has ballooned, this can eat the thrust surface/bearing and wouldn't be the fault of the crank.
Old 04-16-2010, 12:32 PM
From what I've seen, Eagle has had a spate of poorly machined and out of dimension thrust faces in recent years. You don't appear to be alone. With all this Chinese made stuff you have to be very careful some of its quite good and some of it is just junk. The good vendors weed out the junk and scrap it rather than sell it, but this runs your cost up close to that of American made parts. Others just let the buyer beware, it holds the cost down and they just blame all sorts of other things for the failure event. Have you any idea how much power it takes to balloon a converter, are you getting that kind of power?
Bogie
Old 04-16-2010, 12:34 PM
Balooning
Convertor ballooning would also exert the same amount of force on the pump rotor, causing pump failure, which is not the case. I also hold in my hand the original main caps from the old engine and they are fine. Same trans for three yrs. A 700r4 with a .500 boost sleeve is not enough to cause the convertor to push out hard enough to fail a crank. If it were the case, I'd be having allot of Pissed off customers. If i hadn't changed the oil every 1000 miles, this problem would have surfaced quicker. The rings were full of metal causing serious oil consumption. The Engine rebuilder blames the trans, But as a Transmission Specialist, I know my trans. If i am wrong, I will learn. The Engine rpm is no higher than the 350 that came out. Any help on this would be appreciated.
Old 04-16-2010, 12:55 PM
Ballooning
Just to clarify, Ballooning and convertor charge pressure are separate forces.
Old 04-16-2010, 12:57 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
That ballooning was even mentioned in the first place fooled me into thinking this was a high performance vehicle, being used as such. If this is just a dodge being used by the rebuilder, and the vehicle isn't capable of ballooning a TC (either by design OR how it was used), then that's a different animal.
There any unexplained vibration? Is it externally balanced? One piece or two piece rear main seal? If it's a one piece seal crank, there can be an externally weighted flexplate used that does not have the correct counter weight. An externally balanced 383 stroker will require externally balanced damper and flexplate that matches the stroke.
If it comes to litigation, I suppose another expert witness (that doesn't say what the first mechanic says) would help.
I would photograph every stage of the disassembly, if not possible, at least photograph in detail all of the parts, including any unmistakable identifiers.
Old 04-16-2010, 02:18 PM
Convertor ballooning 700r4
I just received a fax from Precision Convertors of new hampdon, Stating that they have Never had an instance were a 700r4 Style (4842) Convertor ballooned. I did not say the Engine Rebuilder is trying to weasle out of his responsibilities. I will leave this for you folks to decide. Its easy to shift the blame, But in this case, The evidence will speak for itself. I am accountable for what i sell. If i buy a convertor and the Lockup lining comes off, I warranty the whole job. Even faulty parts. I have found that word of mouth is your best friend or worst enemy. The integrity of the Engine Rebuilder to stand behind what he sells is in question here. If Eagle has finish problems that cause failures, They should held accountable. Own up, fix it, or get out of the buisiness. This problem may happen to you. Buy the way, Yesterday i spoke with a wholesale engine remanufacturer and he has had a real problem with the Eagle cranks wiping out mains, until he started cleaning up poor grind surfaces. He was man enough to warranty all of the comebacks. Thank you for your input... John
Old 04-16-2010, 02:34 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
John, if ALL businessmen had your ethics, this would be a non-issue.
FWIW, I personally had not heard of any especially bad rash of problems w/Eagle cranks recently- although awhile ago there were reports of problems of (but not limited to) the finish of the thrust surfaces being too rough- this causing thrust bearing wear- even though the end float was checked to be OK. You might look into that in THIS case (the finish quality, that is).
If the crank has been on someone's shelf for a long time, it might even be one of the ones from back when. I would suggest looking it over for any stampings that might indicate a date of manufacture, that might tie it into a bad lot.
Good luck.
Old 04-16-2010, 03:44 PM
Is the damage to the thrust on the rear of the journal? Or, is it on both? It the crank damaged or just the bearing? Is it confined to just the upper or lower half?
Old 04-16-2010, 03:51 PM
A couple things to lok for.
If there's anything left of the thrust faces, the crank's that had problems had a cross hatch finish on the thrust surface not looking unlike what you'd see for a cylinder wall finish, instead of a smooth surface.
The other problem common to thrust bearings is not getting the clearance correct and not getting the upper and lower halves to have the thrust surface smooth across their mating surface. That is one half of the bearing projects above the other. These must meet very smoothly, if not the step between the halves will wipe the oil wedge off and the thrust face of the crank will quickly fail. Many builders just don't pay enough time to insuring this is correct. You have to set the thrust mains into the block and cap. Then inspect both sides for a smooth surface across their interface. Adjust as required, this can range from removing bearing material with oiled wet/dry sand paper to dinging on the surface with a soft hammer. Then disassemble and install all the mains and the crank ans torque it up. Then pry the crank from one end to the other and measure the thrust clearance. Not much can be done for too wide except to replace the crank, for too narrow determine the dimension to be reduced, then take it apart and oil sand the bearing's thrust faces always maintaining the perpendicularity to the crank center and the smoothness of the halves interface. This can be a real time consuming effort to get right, but if it isn't the parts won't last long.
Bogie
Old 04-16-2010, 04:28 PM
Crank Thrust
Unfortunately at this time, i am not in possession of the crank. I will look at the other side grind when i go over there. I can remember having transmission pump seals coming back after six months with ft seal leaks. we traced the problem to the finish on the torque convertor hub wearing away the bushing from pump side load. I could actually catch my fingernail dragging it across the hub. This is, by the way, a one piece rear seal crank. Internally balance with no vibrations. Thanks, John
Cam help please Cory 43 Engine 26 03-26-2010 03:52 PM
could it be a 383 stroker??? elcaminodragster Engine 12 11-21-2007 07:28 PM
Dart Iron Eagle Heads For a 383 stroker truckster69 Engine 3 01-05-2005 03:10 PM
383 Setup, need advice william27103 Engine 7 06-07-2004 10:57 PM
383 Crank/block problem V8 S-10 Engine 7 04-30-2003 06:18 PM
