Eagle Crankshafts - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-03-2007, 02:54 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Eagle Crankshafts
I just ordered a new Eagle internally balanced forged crank for my 400. As some of you may already know this will be the base for a supercharged 400. I've also picked out some 23cc reverse dome forged pistons from JE but have not ordered them yet until I know what bore size I'm going to end up with. I'm also thinking of ordering some Eagle H-beam rods with cap screws, they're 5.7" to correspond with the pistons I've selected. Any suggestions/recommendations?
Old 03-03-2007, 04:57 PM
i think i would order the largest inner cooler i can find...
Old 03-03-2007, 06:16 PM
Blazin72's Avatar
Wiki Edits: 19
I was looking more for info/suggestions on stuff I'm currently considering....I'm not even concerning myself with anything else at the moment...
Old 03-03-2007, 06:59 PM
RPM's Avatar
RPM RPM is offline
World Class ASE tech
Did you order the crank with a double keyway? The stock 3/16 won't hold up long driving the blower.
Old 03-03-2007, 07:06 PM
cabowabo's Avatar
big Q
eagle
you can get away with i beam steel rods if money is a problem they will hold up try these guys they got some real good deals on cranks and rods
www.enginekits.com
Old 03-03-2007, 07:08 PM
techinspector1's Avatar
Wiki Edits: 326
Good point. You'll need a 3/16" and a 1/4" key, 180 degrees apart.
Old 03-04-2007, 02:44 AM
Blazin72's Avatar
Wiki Edits: 19
I didn't even think about that. Thank you. I don't know that it has double keyways. I imagine I'll have to have the machine shop broach a second keyway for me.
Old 03-04-2007, 07:04 AM
RPM's Avatar
RPM RPM is offline
I ordered my Eagle with double keyway and it only took 2 extra days to get it. They charged $50.00 to do it. The blower drive hub fit perfect, when I assembled the engine.
That is someting else. Blower drive hub. Do not use the stock balancer or even a cast it balancer. Use a billet steel hub. From BDS or from Al's.
http://bigalstoybox.com/
http://blowerdriveservice.com/
Old 03-04-2007, 10:26 AM
Blazin72's Avatar
Wiki Edits: 19
RPM, what are you running for an engine and blower?
Old 03-05-2007, 11:08 AM
King of my Man-cave.
Some things to check with Eagle cranks and rods.
Check the rod throws and main journals very carefully. I have had to have several turned because they were too big near the radii.
Check the mains for run-out.
Check the snout size. They tend to run undersize from time to time.
Do have the extra key way machined into it.
Use a blower balancer. Romac has very nice pieces.
Check the balance if it is a balanced kit.
Torque the connecting rod bolts to the proper stretch (they are NOT out-of-the box). Check the rod sizing after, they may need to be honed round after torquing.
Check the pin fit. It is usually too tight.
Other than that, Eagle stuff is fine.
tom
Old 03-05-2007, 04:19 PM
RPM's Avatar
RPM RPM is offline
I built a Small block chevy 350 bored .030. With Eagle crank and rods. Got the engine all built and in the frame but don't have it fired up yet. It has a Wieand 6-71 blower on it.
I can't figure out how to post a picture here but here is a link to the engine.
http://www.nationaltbucketalliance.c...83/blower1.jpg
IDing Eagle con. rods Rocket455 Engine 10 03-03-2007 05:28 PM
383 with 6in eagle h-beams anyone? 383mudlust Engine 21 01-25-2007 10:12 AM
Eagle SIR vs. SCAT rods wild one Engine 6 10-16-2006 03:42 PM
Is an Eagle an AMC or Dodge? Wifes new DD Blackdog Hotrodders' Lounge 11 04-17-2006 11:37 AM
Forged Crankshaft - GM 6223 or Eagle??? swerve Engine 5 04-14-2005 01:04 AM
