Eagle "ESP" Rotating Assy.. - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-25-2009, 02:43 PM
Just looking for some thoughts on this..... thanks in advance...
http://cgi.ebay.com/ebaymotors/SB-Ch...Q5fAccessories
Old 06-25-2009, 07:30 PM
The eagle stuff is not too bad from what I have read. There have been some issues with the connecting rods not being within proper specs for pin diameter size wise but othern then that they are pretty good for a decent street build. Also if you want go with scat they run about the same price and I have used two rotating assemblies from them and they are excellent and the rods you get from them are 4340 not 5140 and are stronger.
Eric
Old 06-26-2009, 05:11 AM
Last journal entry: PICTURE TEST
parts
I have used both eagle and scat rods and cranks. I personally only use eagles "H" beam rod. Everything else i buy scat.
I have never broken any of the eagle cranks or rods, but the quality issue they can have makes it not worth me buying from them anymore.
Keith
Eagle rotating assembly..... Smittydpd Engine 9 04-13-2009 01:25 PM
Pilot bearing -> Eagle crank, SBC, fit too loose 66Chevelle Transmission - Rearend 6 09-29-2008 04:32 PM
383 with 6in eagle h-beams anyone? 383mudlust Engine 21 01-25-2007 10:12 AM
Forged Crankshaft - GM 6223 or Eagle??? swerve Engine 5 04-14-2005 01:04 AM
rotating assy. balancing + mixing parts TerroRx7 Hotrodding Basics 4 04-03-2005 12:48 PM
