eagle or scat - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-26-2002, 01:41 PM
Post eagle or scat
lets say you want to stroke a 350. (383) whats the opinions on either a scat or eagle rotating assembly. either way i it will be around $1800.00 for the whole set up balanced and all. any other possible manufactures putting out a good product? yes forged everything. bushed rods and flat tops.
Old 11-26-2002, 03:12 PM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Post
You should be able to get everything a bit cheaper than that. I would get an Eagle crank form one of the ebay guys. They run about $350. Scat has some new ProMod type rods with 7/16 bolts. Under $300 on Ebay and they appear to be damned nice. I know you are going to hear use the eagles, but I beam promods are superior in strength to to H-Beam Eagles. As for the pistons Wiesco makes a good set for around $550. That puts you at about $1200 plus balancing.
Chris
Old 11-26-2002, 03:36 PM
69 Camaro's Avatar
Post
i like scat because there american made. just my 2 cents
Old 11-26-2002, 05:41 PM
Post
ive heard of eagles being way to *****ey to balance, sometimes the shops end up sending them back....
i think scats a little better than eagle but its not the all around best, but better than eagle
Old 11-26-2002, 07:30 PM
BOBCRMAN@aol.com's Avatar
Post
Scats products are not american made they are just machined in the U.S. a lot of the other after market producers are the same way. most of these crank and rod cores come from China or Spain, some from Argentina or New Zealand
Old 11-27-2002, 02:57 AM
Post
keep em commin the score is at a tie. thanks
Old 11-27-2002, 03:29 AM
engineczar's Avatar
Post
Go with Manley part #18002 you get the crank (2 piece rear main) 6" H-beam rods, forged flat tops, and file fit rings. The kit comes already balanced for the components they send you. All for about $1500 and the quality is first rate.
BSE Racing Engines
Old 11-27-2002, 07:16 AM
Post
thanks, do you think they have one for 1 piece rear main.
Old 11-27-2002, 07:22 AM
engineczar's Avatar
Post
Unfortunatly Manley doesn't list one.
BSE Racing Engines
Old 11-27-2002, 07:25 AM
Post
never mind just got off the phone with them they dint offer a 1 piece. thanks
