EARLS auto-fit hose ends ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-25-2006, 07:00 PM
Vortech 4.3's Avatar
jack of all trades
i need some oil line in -4, and i REALLY want anodized ends. most only go down to -6. but EARLS auto-fit is -4. but i am not sure if i can use them for oil psi lines.
can i ?
thanx
Old 04-26-2006, 07:39 PM
jack of all trades
so. nobody has used these ???
Old 04-26-2006, 11:15 PM
I use em for tranny, fuel, vacuum pump (oily). I think if you keep under 300 continuous degrees, and under 3/4 tons of pressure, you should be good. But do check which hose you're buying because there are different hoses engineered by Earls and others, for different uses. Go to your local hydralic line company and have em make you up some lines. They have the stuff to make your plumbing look any way you want it.
Old 04-27-2006, 10:09 AM
johnsongrass1's Avatar
Race it, Don't rice it!
I use it earls. He gives them too me. I have no issues.
will this hose fit? airman_turtle Engine 5 03-21-2005 02:21 PM
Your not the hose? Dammit..... StrokeofGenius Engine 6 11-17-2004 11:22 AM
early optispark vacuum source 48Man Engine 7 01-16-2003 01:17 PM
Lower Radiator hose Colapse?? HotRodMan Engine 4 09-06-2002 06:17 PM
Ford 400 Press Fit Hose Outlet ???? gohealthyhome Engine 4 07-09-2002 05:31 AM
